Yes, sorry, I guess I meant the first *through* drill. I always use a spotting drill first. If it will be bored to finish, I guess I see the point that it might not be necessary, but I always thought that by not spotting, and having the drills wobble a bit because of an off-center pilot, I was increasing the odds of snapping a bit, so I got in the habit of always doing it.
I have a drill doctor (which I know many of you don't like, but for smaller diameter bits, I've saved shipping a lot of replacement drills over here!), so I can always regrind jobbers into split points, which I now think I might do for some common "entry" drills.
My normal process is to spot, drill through with something like an "S" bit, and then jump to a 7/8" (only because I have a good cobalt one and most of the rest of my MT bits are HSS), then the final size, then usually boring. My smallest good boring bar needs close to 7/8", so that works well (though there have been MANY times where I wish I could fit a bar into a smaller bore, I really need to invest in a good smaller one).
When I was greener, and only used to drilling in drill presses, I did many more steps. Once I got the advice on here to stop doing that, I've never gone back. The holes are better, the chips more impressive, the time less, and it's a lot more fun to watch.
So in the specific case that made me ask this question, I was taking solid 6" stock (8" long, maybe) and prepping it for a mandrel to turn between centers (tube bending dies). In this case, I chucked it with some rough adjusting based on an indicator, center drilled, ran the tailstock center in to stabilize for rough facing and turning cuts, then started drilling. The first drill (as I said, I grabbed for something other than my normal since my normal screw machine starter bit was too short) was 3/8" or so. It drilled pretty much on center (wasn't wobbling in the cut). Then when I went to the 7/8", it bit off center and wobbled a lot. My plan was (after hogging with the 7/8" cobalt drill) to drill with a 63/64" in prep for the 1" reamer, then put the part on the mandrel.
In practice, however, the 7/8" bit so far off center that the 63/64" didn't remove a lot, and the reamer didn't cut anything. The bore is spirally and ugly. In this case, it will be finished out later to 1.280 or something, so I don't care, but I don't like that the process didn't work like I expected.
It seems possible, based on the explanations, that where I went wrong was that the 3/8" long bit I used was too big to let the 7/8" bit bite enough to drill accurately? Think I would've been better off in that case if I'd followed the center drill with something like 1/4"? Even less? I get that we don't want lots more than the web, but isn't there going to be a diameter vs depth problem at some point as we reduce the drill size? An 8" long 1/4" hole is 32 diameters!
Probably exacerbating the situation is the fact that the 7/8" bit was hand sharpened. Although I've gotten pretty good at reproducing the geometry of each lip, I don't yet have a good way to make sure that the lips are equal. So maybe one lip was longer, and it bit first, pushing the drill off center until the other lip finally engaged the work? What's everyone's best trick for making sure the two lips are the same depth when hand sharpening?
Thanks for all of the help. These are rookie questions, I realize, but most of what I've learned has been on PM, with no one local to show me where I'm going wrong, so I have to question stuff I've been doing for a few years to make sure I'm not copying bad habits!
