CatMan
Hot Rolled
- Apr 12, 2005
- Brandon, MS
Got a washer here that has some rust on the ribbon cable. The fault is the ribbon cable is attached to a touch pad, but when I push one button, another lights up. The common failure on this is the rust is "linking" the two wires together, and therefore when I press one button, the signal going back is actually jumping to another button's wire.
Anyway to get rid of some of the rust without compromising the ribbon? I rubbed on it a little bit with a toothpick, but that didn't seem to do much. What would the next step be? Chemical possibilities? Abrade it off with some high grit sandpaper?
