Good material choice for B52 collets
Gobo
Titanium
Jun 4, 2013
Oregon, USA
Because of the crazy lead time and costs for the collets (B52) we use on our tube bender, the choice was made to make our own. What we now have are Rc33, so we would like to make the collets out of a material with comparable hardness. What would be a good choice of material for this project? I was thinking 4140. We will probably purchase them in the future, but lead time is critical.
I would go with ETD 150 .
Stronger and better hardness right form the mill..No post heat treatment machine and in in service...
Easily available even from McMaster-Carr
Cheers Ross
We machine ETD 150 but it is not Rc33. It machines quite nicely. We are somewhat concerned about the finished part "springing" when we EDM the slots in the collet. How much of a concern is that with ETD 150?
I'd recommend that you leave a "ring" of extra material on the nose of the collet until it has been bored and slit. That prevents any motion and provides rigidity during those operations. Then grind or machine off the ring as the last operation. This was traditional for shop-made collets (and maybe OEM collets, but I don't know) which had to go through heat treatment, and would probably provide some value even when you use pre-hard material.
Nice tip about that extra "ring" of material. Thanks. We will make a special collet for a "Tug Gun" tool used to remove valve seats in engine heads.
I will try 4340 HT for this application. 4140 HT would be a good choice also, very similar, though a bit less tough when I check on this nice comparison site: https://www.makeitfrom.com/compare/Normalized-4140-Cr-Mo-Steel/Normalized-4340-Ni-Cr-Mo-Steel
Here is an image of the collet in question:
