Laverda
Cast Iron
- Mar 24, 2014
- Riverside County, CA
I have 3 Sunnen honing machines but have never OD honed. Does it offer any advantages over cylindrical or center-less grinding if you want to make a part (very hard) as round as possible? The area to be ground is only 1" long and 13/16" diameter. I was going to cylindrical grind it (don't have a center less grinder)but was wondering if honing may be better? I only need to grind off a couple thou but need it as perfect as possible and a good surface finish. The OD when done needs to be +/- .0002"
OD hones are crazy expensive but do they do a better job or should I stick to the grinder I have which works great?
Just wondering about OD honing as I know nothing about it. I am probably over thinking this and should just put the part in the cylindrical grinder and be done with it.
