mathamattox
- Nov 1, 2009
- Charlotte, NC
Guys,
The MT3 taper in my tailstock ram is pretty boogered up. I attempted hand reaming and got a little bit of cleanup but nowhere near what I would call acceptable. The reaming mostly just removed the high spots but the gouges still remain. I am skeptical if power reaming would do much better.
I could chuck the ram and try to clean it up using the taper attachment on the lathe, but I honestly don't know if my skills are good enough to get it right.
So, I called around to a few places that advertise "spindle grinding" and most said they could do it. The way they apparently work is you ship your spindle to them, they inspect it and give you a quote to fix it. That seems a bit too "in-depth" for this issue. I was given a verbal quote from one of the places of about $300. That's more than I want to spend but I suppose nobody does a lot of internal MT grinding on spindles so it doesn't seem outrageous.
Anybody know of a small shop that has this capability that might be interested? The part is easy to ship so proximity is not that important.
Jonathan
Jonathan
