Grob or a DoAll vertical band saw 16-24
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Sep 2014
    Georgia
    646
    8
    119
    Default Grob or a DoAll vertical band saw 16-24
    Ive been looking for a decent vertical bandsaw. Around me the only things Ive seen are grob 18/ 24 bandsaws and DoAll bandsaws.
    The DoAll Im looking at is a 16 saw and looks pretty good its been painted etc but its a bit more money.
    The grob is newer and has original paint in ok shape. Its also cheaper. Has a blade welder.
    What are your opinions?
    Ive read on here that the DoAll is superior but is the grob that bad? Its cheaper and more original. I have a horizontal bandsaw aswell so this is just to supplement that.
    May 2006
    Seattle
    2,145
    51
    431
    Research the DoAll 16" models. They vary a lot. I think I wound up concluding the one to look for was a 1612-3.
    I doubt there's anything wrong with a Grob. But look into parts availability and make sure you can get your hands on a manual.
    I looked for quite awhile and wound up buying a 1960s Rockwell Delta 20" vertical band saw. Like a DoAll, it has a 2-speed gearbox and variable speed drive effecting blade speeds of 50-5000 surface feet per minute. No blade welder, sigh. It works fine for my needs and it was cheap. Actually, I got it with a lot of other stuff. After selling off the other stuff the saw was free.
    I suggest you buy what you can find. Use it, and keep looking. If you get that dream DoAll someday, you can sell your Grob.
    metalmagpie
    Sep 2014
    Georgia
    646
    8
    119
    I dont know the model number but here are the two Im looking between at the moment.
    Dec 2019
    Minnesota
    Grob is a well built saw. No reason to shy away from that. In that vintage, the DoAll is also a nice machine. I don't think you could go wrong with either...
  5. Likes mister honey, Casady Machine liked this post
    Oct 2009
    Oregon
    4,956
    5365
    2544
    I had a 24" Grob. I thought it was a bit on the cheezy side.
    I think Doall is a little better quality.
    The Marvel verticals always seemed like the hot ticket to me.
    Oct 2012
    NE Ohio USA
    662
    131
    252
    No vote either way. But I did not notice a blade welder on the DoAll. Looks like the Grob has one. Do yourself a favor and price one of those welders. Nice option to have right on the machine.
    Best Regards,
    Bob
    Mar 2012
    Geilenkirchen, Germany
    2,574
    1515
    1313
    I don't know anything about the Grob saws, but I have a DoAll 1612. When I got the saw, parts of it were really very rough. I sat on it for a long time and finally got around to restoring it. It was a hell of a lot of work, but I totally disassembled it and found that the saw was pretty much as new, but it had been left outside in the rain for a long time and corrosion took its toll. I had to make several parts including a new vertical post. I cleaned, restored and repainted the saw inside and out including the blade welder. I replaced all the wiring because the original wiring was in bad shape and I had to convert the saw from 208V 60Hz to 400V 50Hz. I also made a low boy cradle with wheels so that I could roll it around easily. That was well worth while, as the saw weighs just under 1,000 lbs. It is also quite tall. All that said, there is a wealth of information out there and .pdf manuals are readily available. DoAll was a great deal of help, but their parts, when available are pricey. When parts are no longer available, DoAll sent machine drawings of the original parts. That was very much appreciated. Also our own John Oder right here on PM was also a great deal of help. I did elect to make the entire power feed system because those parts were missing and no longer available. I am now just finishing up the last of dozens and dozens of individual parts. In all, my project has taken about 18 months off and on, but my saw operates like a new machine. It is super easy to use. I have now found all the different blade guides fo all the different size blades it can use. It has been a great project and is a great saw.
  9. #8
    Apr 2004
    Modesto, CA USA
    7,578
    1339
    I believe all grob saws have a threaded hole in the top of the arm for a lifting ring. It is 3/4 or one inch bolt size.
    I believe all grob saws have no gears, it is all belt changes to vary speed. Means getting down and dirty to change speeds but no expensive gears to wear. Do not take this as gospel it is just some long remembered stuff.
    Also the powermatic or the rockwell, not sure which, 20" saw has no drain for the transmission. It has a fill port put no way to drain the old gear oil.
    Bill D.
  10. #9
    Jul 2019
    Florida
    1,658
    1630
    339
    Do all has a History of a good reputation and high quality.
  11. #10
    Sep 2014
    Georgia
    646
    8
    119
    Grob has a transmission and infinite variable speed. Only the old ones had belt changes. No clue on the DoAll
    Question to those out there that know. The grob has a air cylinder behind the table does anybody know what for?
  12. #11
    Apr 2004
    Modesto, CA USA
    7,578
    1339
    The air cylinder may be part of the automatic sawing mechenizim. Simply a chain or cable that pulls down at the outfeed end off the table. Simple ones hang a weight more complex use air or a damper to control rate,. The chain is hooked to the work and pulls it into the blade. Leave it unattended and it cuts the work then it cuts the puller in two as well. Having this feature makes it a "contour" saw.
    Bil lD
  13. #12
    Michigan
    112
    66
    I have a 16" DoAll, and my Uncle has a 24" GROB in his shop. They are both good saws, but I prefer the controls and UI on the DoAll. I have run the snot out of mine, and it has never let me down.
    I do know my DoAll is built like a brick shithouse, and is a heavy sunofabitch. It has a threaded receiver for a lift eye on top that makes moving it with the bridge crane a snap though.
  14. #13
    Dec 2011
    AFGHANISTAN
    1,334
    1749
    572
    dude... just keep it simple and get one of those stands for your portaband.. i mean the home shop homies seem to love them.
  15. #14
    Sep 2014
    Georgia
    646
    8
    119
    Quote Originally Posted by vanguard machine View Post
    10-4 got one on order. You think it will cut the 1.5 steel bar alright though?
  16. Likes vanguard machine liked this post
  17. #15
    Mar 2007
    Milford,Ct
    491
    447
    109
    Choice between Grob or DoAll I would purchase which ever was in better shape.Both are good saws, I have used both and prefer the Grob but that is just me .I also own a Grob . Bill
  18. #16
    Sep 2004
    Louisville, KY
    1,188
    401
    413
    I have a Grob...well used but I like it. It has a transmission and variable speed as mentioned.
    Very heavy and nicely built imo. It seems many prefer the guides on the do-all vs the grob.
    I bought a tire/glue for mine directly from Grob. They were helpful.
    Mine has the air cyl feed and blade welder.
    I'm with whoever mentioned buying the best of what's available.
    Pic of mine....$500 auction find.
  19. #17
    May 2019
    GUADELOUPE
    955
    333
    452
    I have a DoAll horizontal automatic and it is built like a brick shithouse at close to 5000 pounds. Has no trouble pulling a 2 pitch blade. I don't have a big vertical but if I were to get one it would likely be a roll in saw
  20. #18
    Sep 2014
    Georgia
    646
    8
    119
    Quote Originally Posted by jamscal View Post
    I missed out on one a year or so ago for $900 in decent shape probably could have offered the guy less honestly. Just didnt have the space for it at the time.
    Well the DoAll saw looks like it was reconditioned but the grob looks original and has air feed cylinder and blade welder. Im gonna make the guy an offer but its a long ways away so Ill see if I get it.
  21. #19
    Feb 2020
    North Carolina
    6
    I have a DoAll 3613 and a Grob NS18. The DoAll is a beast but I am partial to the Grob, mainly due to the condition it is in. Can't go wrong with either one.
  22. #20
    Sep 2014
    Georgia
    646
    8
    119
    Quote Originally Posted by Ironhead52 View Post
    The ns18 are the old ones do they have any flaws to where I should look for a newer one?
    I seen a ns18 for sale but no vari speed setup.
    But I have a couple vfds laying around I could make my own variable speed control.
