Hand Opp Rad / Chamfer Power Rool
Results 1 to 9 of 9
    Aug 2002
    West Unity, Ohio
    26,217
    6492
    8615
    Default Hand Opp Rad / Chamfer Power Rool
    I haven't seen anything quite like this before.
    (doesn't mean they don't exist)
    Could be quite beneficial for manual opps, as well as back-side CNC opps.
    SP-7252F Air Mini Beveler - SP Air USA
    Think Snow Eh!
    Ox
    Oct 2005
    17,697
    Interestingah.
    Looks similar:
    LSB38 Bevelling Tool - Atlas Copco USA
    I think I've seen similar, but with a vertical motor, just like a laminate trim tool. Which I think might be more ergonomic, where as the right angle design makes it harder to keep the tool flat on that flange.
    Mar 2009
    Brunswick Oh USA
    4,617
    5245
    2749
    Neat tool. Music SUCKS!
    Feb 2020
    Maryland
    37
    Tool Discounter sells it for $268. Might be good if you need it all the time. Otherwise an electric wood router with a carbide bit will work and give a wider range of edge shapes.
  5. Likes bryan_machine liked this post
    Oct 2005
    17,697
    Quote Originally Posted by Superbowl View Post
    Might want to put some filter material over the electric motor's air intake....
    Feb 2007
    Aberdeen, UK
    3,900
    1383
    1584
    I use a variable speed router mounted upside down on a piece of plywood, like a spindle moulder, for doing this. Only ever tried it on aluminium though...
  8. Likes bryan_machine liked this post
  9. #7
    Jun 2006
    Near Seattle
    4,951
    3403
    1418
    gregormarwick - What kind of router bit do you find best?
  10. #8
    Feb 2007
    Aberdeen, UK
    3,900
    1383
    1584
    Quote Originally Posted by bryan_machine View Post
    I'm afraid I don't really know anything about router bits. It's just brazed carbide with two blades and small bearing for following the edge.
  11. Likes bryan_machine liked this post
  12. #9
    Jan 2007
    wales.uk
    1,194
    131
    186
    I used one of these recently, awesome
    Bevelling tools | Metal processing | Metabo Power Tools
    Bit pricy though
    Mark
