I'm using "security hardware" that normally consists of two sliding brackets on the top and a pin on the bottom that turns to secure paintings and things to walls. I have an application where I would like to use 3 of the pins to hang an aluminum flat sculpture to the wall instead of using the 2 sliding brackets and pin. The reason for the 3 pins is that it's an open sculpture and the pins are more minimal looking.
Someone told me that it can't be done since the pins are not load-bearing. However, the pin screws are bigger than the bracket screws, and the sculpture only weighs about 40 lbs. Structurally, if there is a screw with a bracket on the wall, or the same screw with no bracket, and there is a radial(?) force pulling down on the screw, isn't it just about the same in terms of "load-bearing"?
In other words, a #6 screw in a plastic plug in drywall is going to hold about the same amount of weight as a #6 screw in a plastic plug - with a bracket - in drywall correct?
I realize that the bracket spreads the load a bit on the wall but I think that the pull-out strength is going to be about the same. Would you agree or disagree?
