TastyMuffinTops
- Dec 9, 2017
Hello,
I am looking to harden a .125x2x8 piece of A2 tool steel. It has a beveled edge with a .030 flat on along the bottom of it. It is a straight edge for my girlfriend (she does drafting). I don't want it to lose the edge when she is constantly rubbing and cutting against it.
At work, we harden it at 1750 in foil and paper, let it cool furnace night, and then put it in a toaster oven at 450 for two hours on, an hour off, then two hours on again, and then let it cool down in the oven over night.
From what I have read, that seems pretty standard. My boss says I don't need to harden and temper it for what its purpose is. Says its plenty hard enough. But I don't think that sounds right. I already had to grind a ding out. Is he right? I also read that I shouldn't have beveled it before hand. Is that right as well? I'm still trying to figure out the ropes of heat treating. Should I also have plates handy to help prevent warping due to its thickness, length, and bevel? My boss says nah to that as well.
Thanks for the help.
P. S. I also have some bluing questions if you guys are up for that. Be much appreciated!
P. P. S. This is also my second attempt at this post. The first one didn't show up, sorry for the double posting
