Hi nt1953:
If you can just barely cut it with a new single cut mill bastard file and heavy pressure it's about 50 RC.
That's too hard to broach with HSS.
So if you MUST have it as close to the original as possible in material properties you have three choices:
1) Make it in the soft state and harden it.
2) Do as Thermite recommends and have the keyways EDM cut (sinker for blind ones and wire for through ones)
3) Fuck around half of forever with a single point carbide shaper tool rigged up in your lathe or mill and try to nibble it out in the hard state.
If you judge you can go softer without detriment to the function, then I'd go with 4140 HTSR or P-20 Hi Hard which gets you in the low Rockwell 30's.
If you want to make it in the soft state and harden it, you can choose an air hardening tool steel so it doesn't warp too badly during HT or you can plan to leave stock for finishing and just re-machine it after HT.
I have four favourites I use routinely:
1) A-2
2) H-13
3) 420M Stainless
4) 17-4 PH Stainless
All but the last will go up over 50 RC
17-4 PH at condition H900 gets up to close to 45 RC
All are pretty stable in HT and will not warp badly.
Cheers
Marcus
