Hardinge HF-6 Bar Feed
Flute Maker
Cast Iron
Feb 17, 2007
Needham, MA
Good morning,
We have this Hardinge bare feed. Some parts are still available for it from Hardinge. I'm looking for a little more info about its mechanics than Hardinge can give me. It was obsoleted in 2005. Does anyone have a working unit? Is there a similar device out there? It's used on a hand screw machine.
Thank you,
Payson.
Good morning,
Thank you,
Payson.
Pix would help allot here.
Thanks for the quick reply. Your bar feed is a bit more sophisticated than ours. Linda at Hardinge is sending me some new cups and o-rings. I took it apart and swabbed it all out yesterday. My only questions now are:
1. have you bothered to change the bearings in the front of the pusher,
2. is there an o-ring anywhere in that front section?
Best regards,
Payson.
I've never done anything to it. In fact, since I got a CNC lathe with barloader I don't even use it anymore.
I'd have to look for the O-ring. It's in storage . Give me a little bit so I call pull it down.
No O-ring on the pusher. There is an O-ring in the end of the main body. I assume to hold the reducing bushing in.
