Hardinge HLV-H VS Feeler high accuracy lathe cut off attachment
Results 1 to 6 of 6
    Sep 2006
    Nevada
    402
    27
    103
    Default Hardinge HLV-H VS Feeler high accuracy lathe cut off attachment
    Does anyone know if the bolt pattern on a Hardinge cutoff attachment that bolts to the headstock will match the bolt pattern on the Feeler copy of the Hardinge lathe? Trying to locate one and want to know what will work before buying something that is a mismatch.
    Feb 2006
    Indiana
    13,767
    787
    4549
    Around 1983, I bought a new Feeler vertical cutoff for their copy of a DSM-59. It was, of course, cheaper than buying from Hardinge. I put it on my 1944 Hardinge ESM-59 and had to slot the three mounting screw holes to line up with the tapped holes in the lathe. But the recess for the bearing retainer was the right size. Recently, I got a Hardinge HSL, which shares spindle design with the 1960 DSM-59. The Feeler vertical cutoff fits the HSL and the original Feeler screw holes line up with the tapped holes in the HSL. So, Hardinge changed the location of the tapped holes between 1944 and 1960. I suspect that Feeler made a very close copy of the 1960 DSM-59. I don't know if they used USA screw threads, though.
    Anyway, I have a vertical cutoff for the 1960 HLV-H for sale. It is in excellent condition and has a new blade. The recess for the bearing retainer is about 5.50" dia. and the bolt circle is about 4.88" dia., for 5/16-18 screws. Three screws about 3/8" longer than normal are required to attach the cutoff. It uses Empire T-shaped blades.
    Larry
  3. Likes cyanidekid liked this post
    Jul 2007
    Brookfield, WI
    668
    930
    601
    I clicked on this post when I saw that Larry Vanice was the last poster. I don't have a Hardinge; I don't have a Feeler, so why should care? Because I know that Larry's response will be spot-on helpful. And it was. Thanks for all your help, Larry
    Ron Hofer
  5. Likes old_dave liked this post
  6. #4
    Feb 2004
    peekskill, NY
    26,597
    6036
    Quote Originally Posted by L Vanice View Post
    .... Hardinge changed the location of the tapped holes between 1944 and 1960. ...
    I found this out when I bought a headstock mounted cutoff for my ESM-59, had to drift the mounting holes in it a bit.
  7. #5
    Oct 2010
    Dewees Texas
    3,074
    33
    1012
    Quote Originally Posted by Ron Hofer View Post
    Ron Hofer
    Yep, Larry is most helpful. I have bought things from him that the OP's passed on and they were better than advertised.
    If ShayBuilder passes on that cut off I am next in line!
  8. #6
    Sep 2009
    Apex, NC
    1,687
    844
    Not to hijack the thread, but FYI on a related note, the spindle horizontal position on a Feeler versus HLVH must be about 3/8" displaced to the right (looking at the spindle head-on); found that out when I bought a Feeler steady-rest for the Hardinge and had to add a thick epoxied-on shim on the dovetail, and machine relief in the right (locking side) of the casting.
