Hi guys
I usually just read n learn . Ive done a search but gotta post.
Q : Does anyone here know the taper angle of the Harley big twin motor sprocket shaft on the sprocket side ? ? ?
its readily available info to quote 6 degrees which is the angle for the flywheel side of the shaft , then there was a change to 8 1/2 degrees .
there is no reference to the sprocket side .
#24001-30 this is VL , knuckle ,pan up to 1954 when splines came along .
#24000-29 this is DL RL WL 1929 to 1973
#352-25 this is the JD shaft to 1929, WL sprocket fits
#33-2001 this is S&S equivalent to HD big twin ....
I emailed to ask the taper angle of their product ...
their response = "1.000" taper" ..... which is meaningless to anyone
reason Im asking is there are chinese sprockets that V Twin etc sell that are the wrong taper so I started asking around and no one seems to know ....
cheers
cheers
