Harrison M400 Lathe feed gear
Likes Likes:  0
Results 1 to 3 of 3
    May 2020
    UNITED KINGDOM
    Default Harrison M400 Lathe feed gear
    Hi I have a Harrison M400 lathe, I have a question about the feed selectors, does anyone know what the feed rate is for each setting? There is no information on the lathe or in the manual I have. Thanks
    Apr 2004
    Modesto, CA USA
    7,500
    1315
    Mar 2019
    UNITED KINGDOM
    207
    40
    Spend an after noon with a depth mic and select each feed at a time while rotating the spindle exactly one turn. Then mark our what combination does what. Should give you pretty good results.
