DavidScott
- Jul 11, 2012
- Washington
Right now it's dropping the air temp into my shop 19F, 90 outside, 71 inside. Whenever it's hot here the humidity is below 30% and often it's below 20%. I already am pumping 300-500 cfm out of my machines enclosure so I didn't need a fan, just a wet pad in the window I use to let air in. It's just my first mockup to see if it would even work so now I need to make a frame, add some more pad to fill the window, I got about 3 times more than you see, and I think it's a keeper. It certainly helps keep the shop cooler.
