Has anyone ever made a reduction gearbox?
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,538
    441
    2070
    Default Has anyone ever made a reduction gearbox?
    I need to make an inline reduction gearbox of close to 1.5:1 ratio to slow the output of a small 27hp diesel motor to 1500rpm to run a generator. No more then 50ft lb's torque on the input.
    Are these incredibly complex things to build or just relatively basic so long as you have good common sense.
    Mar 2012
    Geilenkirchen, Germany
    2,399
    1446
    1222
    Quote Originally Posted by RC99 View Post
    I don't think it would be overly difficult, but I can't believe it makes any economic sense or is in the least bit practical. It appears you have a 4 pole alternator and want to make 50 Hz power. You are far better off selling your 4 pole and buying a 2 pole alternator, then get the correct engine governor and be done with the problem.
    Jan 2005
    The Netherlands
    5,821
    276
    1496
    Why not use a V-belt transmission ?
    Peter
  4. Likes Kjelle liked this post
    Jul 2006
    Hillsboro, New Hampshire
    7,751
    1811
    5453
    I've seen simple toothed-belt with taper roller bearings supported shafts used for stepping down engine output, and that unit lasted for years. But I'm surprised that your engine has a base RPM of 7500, that's awfully high for a diesel.
    May 2012
    Pittsford, NY
    1,038
    717
    668
    Old guy I knew made a 2:1 out of the sprockets and chain from an car engine. I don't know if that is too far off for you. A lot less critical than gears. Autozone sells a silent chain set for $22.99. https://www.autozone.com/internal-en...52881_690132_0
    A little research may find mixed automotive parts that would get you closer to 1.5 to 1.
    May 2017
    FINLAND
    1,777
    496
    812
    1½ to 1
    I'd also take a hard look on belt drive possibility, lot more forgiving to build than inline gearbox.
  8. Likes Kjelle liked this post
  9. #7
    Jul 2006
    7,751
    1811
    5453
    Quote Originally Posted by MattiJ View Post
    1½ to 1
    Too early in the morning for me, I misread it as 5:1. D'Oh!
  10. #8
    May 2017
    Massachusetts
    318
    325
    161
    I'm going to second the belt drive simplicity. There are pto driven chippers that achieve a similar result with a jack-shaft pulley arrangement (3 v belts to handle the load).
  11. #9
    Sep 2010
    Oklahoma City, OK
    4,472
    773
    1849
    Belt drive could even still be inline, just require a mid-shaft.
  12. #10
    Oct 2005
    15,612
  13. #11
    Apr 2010
    Wisconsin
    6,106
    4195
    3758
    Make them all the time. Planetaries, even. For your needs, you'd do well to heed the advice given and look at pulleys, belts, and jack shafts. Easy-peasy.
  14. Likes RC99, Demon73, 10 fingers, gmoushon, Kjelle and 2 others liked this post
  15. #12
    May 2017
    Massachusetts
    318
    325
    161
    One cautionary note (not to dissuade from going the pulley route) but just to consider.
    A gearbox will usually pretty much lock in alignment. A simple and cheap pulley/jack-shaft arrangement is often based on pillow-blocks. Those arrangements can be sensitive to alignment issues. I snapped a 1 1/2" chipper jack shaft after carelessly keeping the chipper engaged while I lifted the implement. Resulted in a minor misalignment of the input shaft which wobbled the jackshaft without my realizing it. The fatigue from running the misaligned 1 1/2" shaft even for just a minute or two snapped it like a toothpick.
    Not saying that misalignment couldn't damage a gearbox...and not saying it wasn't 100% user error on my part...just observing pillow blocks don't take much torque to misalign.
  16. #13
    Mar 2009
    Brunswick Oh USA
    4,535
    5069
    2704
    I agree with Zanhrad. Here;s a simple reduction I made for my snow blower. Worked fine, just took forever. Poke the pic for more.
  17. Likes RC99, Dualkit, atomarc, sandiapaul, Demon73 liked this post
  18. #14
    Jul 2006
    Australia (Hobart)
    3,580
    569
    2715
    I've got a 2 pole 7.5kW generator head I'd swap for a 4 pole..... freight/distance probably a deal killer though. Or I could do you a good deal on a Lister 1500/1800 rpm diesel. Kind of planning the same thing as you but the reverse - I need to get the generator head up to 3000 rpm.
    Email me if you're interested. We might be able to work something out on freight as I'm driving north in another month or 2.
    PDW
  19. #15
    Jul 2004
    Houston, TX USA
    30,053
    Here are two "coaxial" or inline reducers I used on this head stock over 30 years back. So you can certainly BUY such things
  20. #16
    Dec 2004
    uk
    14,057
    4552
    6704
    Honestly the hardest bit is making it oil tight, the gears are best bought of the shelf the rest is a couple of bearing fits, Holding shaft centers to typical good machining tolerances works just fine.
    Belt drive and out of line is far easier, but most small alternators are not setup for belt drive side loads.
  21. #17
    Apr 2005
    Beaverdam, Virginia
    7,452
    704
    3518
    Quote Originally Posted by adama View Post
    You would be surprised at some of the loads we put on beefed up automobile alternators and never smoked any bearings. We are talking spinning 200+ amp alternators at over 8,000 RPM with nothing but the stock cheap Chinese bearings in them that at the time in volume cost a measly $1.50 each. Due to the excessive drag created the belt had to be run on the tight side.
  22. #18
    Mar 2005
    5,538
    441
    2070
    Thanks, I did consider belt drive but wanted to get away from that. I could buy a 2 pole but a suitable one is $2000. Compared to the current $0 in the current one, which if sold would only be worth scrap as who would believe you it worked. It is a good alternator 15kVa continuous @ 240V 0.8 pa.
    Still keeping my options open.
  23. #19
    Jul 2006
    Australia (Hobart)
    3,580
    569
    2715
    My plan is/was to use belts but I've got an alternator that has bearings front & back not using the crankshaft to provide the front bearing. Plus I have 2 spare air cooled diesel engines.
    An inline gearbox would be a lot neater though.
    PDW
  24. #20
    Dec 2004
    uk
    14,057
    4552
    6704
    Quote Originally Posted by Dualkit View Post
    Yes car alternators have bearings both ends, lots of generator mounted "power aka mains voltage" alternators only have a bearing the far end! its how they effectively get around the whole shaft alignment issue. Equally they tend to bolt straight onto the fly wheel face, so lots don't even really have a shaft more some kinda coupling flange.
    200 amps at 12v is only what 2.4Kw? Aka 3hp ish? Were looking at 15kw over 6 times more transmitted power here and far more than a single V belt will transmit.
