Having Fun in my shop.
Likes Likes:  0
Results 1 to 18 of 18
    Aug 2008
    Murfreesboro, TN. USA
    691
    136
    Default Having Fun in my shop.
    What do you use your shop for besides work? Got any hobbies? What do you do for fun?
    Now that I am retired, for the past 2 years I have been building a lot of different types of recumbent bikes in my shop. I make a lot of parts on the Bridgepoet Mill and Churchill Lathe without this equipment I could not build these bikes. The back wheel mounting brackets take the most time to cut out on the mill, about 2 hours work. Wish I had a lazer it could cut this part is about 20 seconds. I have built welding fixtures for all these bikes so I can build more if I want. The best part is riding the bikes expecially in nice weather. I still need a tubing roller I may order one from Harbor Freight. My favorite bike is the Lowracer it is the most fun to ride and it is very aerodynamic so that makes it very fast. I can cruise along at 24 mph fairly easy. If I pedal hard I can get it up to 27 mph. Not bad for someone my age.
    This is the Low Racer that I built. I put about 1200 miles on this bike during the summer. This bike weighs 27 lbs. I took the picture without the seat pad.
    This is my Tour Easy bike it is a very confertable ride. I did a 300 mile bike ride through the Blue Ridge mountains of Virginia last summer. I camped in a tent every night it was a lot of fun. This is not a fast ride I cruise along at about 12 to 14 mph most of the time. If I pedal hard I can do 18 to 20 mph. I put about 1500 miles on this bike during the summer. This bike is a little on the heavy side 37 lbs. I have a bike trailer for this bike I can haul 125 lbs of stuff, tent, sleeping bag, food, water, etc.
    This is my P-38 bike it is very manoverable like a sports car. Lots of fun to ride and it is reasonable fast. I can cruise along at 16 to 18 mph. If I pedal hard I can do 22 mph. This bike weighs 21 lbs.
    I sure wish I could find a faster way to make these metal parts and a faster way to cut these angles in the tubing using my mill. First bike is always the slowest to build I have to figure out all the angles, lengths, then do a test ride and work out the bugs. I have 18 different bikes I won't list them all.
    I also build and fly Control Line Model Airplanes. I have to build the motor mounts, landing gears, bell crank, and several other metal parts in my shop. I have several airplane the Twister is my favoriate.
    Here is a jet engine that I built.
    Ok.......one more. Here is 1 of many hot air engines that I have built. Check out my 4 video on You Tube. I also have steam engines. A 6 cylinder model radial engine and several more model engines.
    http://www.youtube.com/watch?v=57GFrxz_mnw
    Here is what may be the worlds faster go cart with a 4 cylinder 65 HP mercury outboard engine power head. The go cart will do 87 mph the way I have it geared. It will do 87 mph in 3 seconds. Lots of machine work here, it took me a month to build this.
    Here is a pic of my largest Tesla Coil it makes 12 foot long sparks. It is fun to play around with. I have several Tesla coils each one is a different size. Smallest is a desk top model. I wind all my coils in the lathe.
    OK guys what do you use your mill, lathe, welder, and other shop equipment for FUN and Hobby?
    keithmech Guest
    Whats with the yellow for recumbents anyway?I added suspension to mine for that
    soft on the butt type of ride.I molded the seat from frp using an old school desk seat as a mold.Bike has many miles on it.
    Jun 2006
    Taylorsville Ky
    3,122
    34
    Are those recumbent bikes you lay flat on your back comfortable to ride???
    Aug 2008
    691
    136
    Quote Originally Posted by Carl Darnell View Post
    Yes it is very comfortable to ride, I have a 2" thick foam pad made especially for recumbent bikes. I love this bike. It takes about 10 minutes of practice to learn to ride a lowracer bike. If you can ride a normal upright bike then you can ride a lowracer too. Wind resistance is about 70% less than a upright bike so that makes it easy to go fast. It takes a couple of weeks to feel relaxed riding a low racer bike. A nice soft head rest is a must have and a good mirror on the helmet.
    Mar 2008
    Antwerp, OH
    18
    Default "Bent" Bikes and Trikes
    After an injury, I lost my sense of balance. I missed riding, and I knew a trike was what I needed, so I decided to build a "bent" trike. Mine is long and low. It's rather heavy, but it's fun to ride. Once on a trip to my Sister's in Florida, I rode across the world's longest over-water bike trail: an abandoned bridge across Tampa Bay. It has a high arch in the center to let boats pass under. Lemme tell ya: riding up the arch was a bitch, but coming back down the other side, sitting with my butt about 6" off the pavement, I made almost 60MPH! THAT was travelling FAST for an ole country boy on a touring machine!
    Ennyway, your 'bents are a lot better looking prouct than mine, which is welded up from miscelllanious old bicycles. Those pictured are very nice! Keep up the good work!
    OhioTom
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,214
    1590
    2569
    Wow dude.....you rock.
    The Low Racer is really cool.
    Ever consider selling plans for it??
    I think EVERY kid should be required to build and fly model airplanes.
    After model trains from age 5 to around 7....model airplanes are what got me interested in machining (along with live steam models).
    The hobby (model airplanes) teaches SO much about engineering, physics, aerodynamics, project management, planning, follow thru, etc, etc.
    Jeesh.....COOL
    A WHOLE month to build it huh?
    Well, if you'd quit building and riding those damn cool bikes thousands of miles you might have gotten it done in a day or two.....
    COOL STUFF!
    Feb 2006
    Oakland, California, USA
    1,782
    17
    13
    I am in no way belittling your kart, I figure you can appreciate one of my favorite videos --- mostly because the guy driving can REALLY drive.
    http://www.youtube.com/watch?v=ddhrD3a2I1M
    Awesome work, I admire your projects!
    Jan 2002
    9,214
    1590
    2569
    ya.....Gixxer.......
    I got this 1982 Kart .......and this Kaw/H2 750 3cyl
    (from the scrap yard 20 years ago)
    maybe some day.......
    But.
    someday never comes.... http://www.youtube.com/watch?v=NwNuQulK6N0
    Aug 2002
    West Unity, Ohio
    26,361
    6669
    8727
    Repairing 2 strokes count? I Shirley don't find it fun, but it is part of keeping toys running. I just need to pony up for 4 strokes eventually...
    Wife wants me to sell the ATV's as I don't use them enymore...
    Think Snow Eh!
    Ox
    Aug 2005
    Toronto
    5,257
    3509
    4074
    great stuff Gary.
    my shop fun is staid in comparison; model engines...steam, gas, atmostpheric
  11. #11
    Jul 2004
    Vicksburg, MS
    4,931
    30
    259
    Mcgyver,
    Did you cast the parts for that triple yourself? It is a triple expansion correct, I'm not a steam nut, just interested. Great work to everyone that has posted. Love that Tesla coil FUN!
  12. #12
    Oct 2002
    Ky.
    179
    Default My hobby work
    When not manufacturing machinery, I keep busy making my replica car. Here is my version of a 1906 Oldsmobile Model B. It is powered by a 12 hp Briggs electric start engine and a hydrostatic transmission from a Sears riding lawn mower. Its top speed is 9 mph. Which is more than enough when steering with a tiller arm. It took 2-1/2 years to get it to this point. I am now working on a fringed surrey top for it. I have had it in 3 parades so far.
    Attached Thumbnails Attached Thumbnails img_0272-000-copy-2-.jpg   img_2092-copy-2-.jpg   img_2258-copy-1-.jpg
  13. #13
    Aug 2005
    Toronto
    5,257
    3509
    4074
    Quote Originally Posted by jkilroy View Post
    Mcgyver,
    not in this lifetime lol, its a stuart turner. their iron castings are very well done, die cast perhaps? not sure if that is possible with cast iron but the finish is very smooth, dimensional accurate and never a chill spot
  14. #14
    Apr 2007
    Hertfordshire, England
    1,245
    330
    58
    Quote Originally Posted by Mcgyver View Post
    Definately the best castings ever, lovely to work with.
    Man, there's some cool stuff in this thread
    Dave
  15. #15
    Jun 2006
    Taylorsville Ky
    3,122
    34
    Endoro carts go over 200 mph and are extremely fast on acceleration.
  16. #16
    Aug 2008
    691
    136
    great stuff Gary.
    That is a really cool steam engine. I have built a few steam engine but nothing as nice as yours.
    I build a Rider Ericsson from a kit once about 10 years ago.
    I build that exact same atmostpheric engine also known as a fire eater or vaccuum engine from the plans in a book. I bought Steam and Steriling book #1 and #2. I also have the book, Elmers Engines. I had some trouble building that valve on the fire water engine my flame gets to hot the spring is lost in the metal that holds the valve shut so my engine doesn't very well any more.
  17. #17
    Aug 2008
    691
    136
    I use to race go carts years ago but I did oval track racing. Did you every run that 20 mile Endoro cart race near Atlanta GA. They block off 20 miles of the highway to get a loop through the mountains, they do a 500 mile race once a year. Pit stops to refuel and change tires. Fuel tanks are between the wheels on each side. The driver is laying on his back for low wind resistance the go carts are doing 140 mph. That is really a cool race it has been 25 years since I was there, not sure they still have that race near Atlanta I have been out of racing for years.
  18. #18
    Jun 2006
    Taylorsville Ky
    3,122
    34
    No, I never did the Endoro's. I raced sprint carts at an outlaw track at Metropolis Ill. I raced for about 3 years and then sold everything. We were living in Charleston Mo at the time and I had a lawn mower shop.
