IQRaceworks
- Jun 18, 2010
- MISSOURI
I picked up a nice used Quincy 325 air compressor with a 5hp motor, and 80gal horizontal tank. It seems to run great, but when it reaches pressure and shuts off....it's not unloading out of the unloader tower like it's supposed to.
I disconnect the exit site of the hydraulic unloader valve mounted on the side of the compressor crankcase, and when there is air pressure in the tank....and the compressor is turned off with no oil pressure....no air is flowing out of the valve. I'm pretty sure that air should be flowing through it to the unloader tower when there is no oil pressure......and then when you turn the compressor on and the oil pressure builds, the valve closes....and the unloader tower closes....and the compressor starts to build pressure.
Is it possible that something inside the hydrualic unloader valve is stuck? Is this common? According to the manual I found online, there are some check balls in there...maybe they are rusted up?
What should I check next? Any ideas would be great!!
Thanks!
Thanks!
