Laverda
Cast Iron
- Mar 24, 2014
- Riverside County, CA
I was going to make a box to case harden a 8620 shaft out of sheet metal. Now I am wondering if I could just use some iron plumbing pipe and screw a cap on each end? I will be stripping off the plating and drill a tiny air hole in one end cap. Any problems with this? Does the material used to make the box make any difference as long as it does not melt? I am assuming the iron pipe once the zinc plating is gone will work OK? It will be in the oven at 1700 degrees for 6 hours.
