Just a Sparky
Hot Rolled
- May 2, 2020
- Minnesota
Just started poking around on the local steel house's website as I'm taking down notes for my next material run and ran into a decision to make.
I'm looking at machining a new shaft for an old motor with bronze bearings and I now have to decide on an alloy and temper of steel to turn it from. The long and short of it is I've got so many other things floating around in my mind right now between this and other projects that I could really use a hand getting up to speed with heat treatment.
I need to make some bearing journals and I've got a lathe, sandpaper and an induction heater. Is heat treating 4140 something I should even waste time thinking about in a home shop environment? Should I just buy heat-treated stock and deal with any added difficulty which might be involved in machining it? Or would annealed 4140 be just fine for a V-belt drive bearing journal?
Thanks guys.
Thanks guys.
