JimGlass
Stainless
- Jan 15, 2003
- Genoa, Illinois
I need to make some parts from 3/16" dia 17-4 stainless. The print calls for 17-4 PH (H1150).
My local steel suppliers are unable to obtain this grade (PH) of stainless in diameters under 1/2".
Can I buy 3/16 dia annealed 17-4 stainless then heat treat after machining. I did some research and sources say it is a precipitation heat treating. Heat the parts to 1150 degrees and hold for 4 hours then quench in still air. My heat treater says it will cost $150 to heat treat 25 pieces 3/16 dia X 5" long.
Can I heat treat these parts in my own heat treat oven. I heat treat tool steels all the time but never any stainless steel.
I'm clueless on this stainless steel.
Jim
Jim
