Bendak
- Aug 26, 2017
Hi all,
I have a 0.375" OD by 0.259" ID 4130 pipe 16" long that needs to be heat treated to increase its yield strength to at least 1300MPa without becoming too brittle. From what I can find online, I need to raise it to 1575°F for 30 minutes followed by an oil (instead of water due to fragile dimensions; need to reduce cracking and distortion) quench and then temper it for two cycles at 400°F for 60 minutes each. This should bring the yield strength to about 1331MPa with a hardness of 47-49HRC. Based on my calculations and simulations in SolidWorks, the pipe will be able to withstand up to 70-71ft*lbs of torque under these conditions. Unfortunately I cannot find 4140 or 4340 pipe with these OD and ID dimensions, so I need to stick with 4130.
I realize that at this hardness, the yield strength will be close to its ultimate tensile strength (1600MPa) and therefore have much less flexibility under torsion. The pipe will have a hollow screw made machined out of 4340 TIG welded on one end for cutting into live wood, and so will be hand operated at about 60 RPM.
Do you all think this is reasonable? I do not want to risk breaking the shaft under a load that may reach up to 65+ ft*lbs of torque, so there needs to be at least some flexibility.
Regards,
Jack
Regards,
Jack
