Heat Treating in a Controlled Atmosphere
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Feb 2011
    2,569
    2111
    1139
    Default Heat Treating in a Controlled Atmosphere
    So we had bought a second oven a few years back, and we opted for one with the plumbing for a controlled atmosphere. Initially we thought about using Compressed C02 to carborize parts, but then we realized that the risk of asphyxiation wasn't worth it so we stuck with our usual procedures of treating O1, A2, D2 steels and using stainless bags to seal them.
    We're currently trying to improve the process for a D2 part that looks like a long skinny blade. It's not sharp but rather acts as a precise guide for another sliding part. These pieces tend to bow when treated, so we're looking for a way to make them that's less involved than the typical rough cut, stress relief, finish cut, stress relief, heat treat, grind, etc. until it's mostly within flatness tolerances.
    We've tried bolting a pair together, and bolting them to a "tombstone" fixture, with varied success, but one idea one of our guys had was to hang them vertically off a little rack. To do so we couldn't wrap them, so we're revisiting the atmosphere feature on the oven.
    Currently it is plumbed to Argon and is getting 5 lbs. positive pressure. I heat treated a drop of D2 last night and started running the Argon with a closed door as soon as I started a heat treating cycle, thinking the air would be forced out. The oven is 13"x13"x36". Went through a cycle and the piece scaled badly. I'm thinking that the air was trapped in there, so how is the oxygen supposed to escape and be replaced by Argon? There is only one inlet into the oven for the gas, but no outlets, so I'm thinking the door is the only escape? Argon is heavier than air too, so should I leave the door cracked on top?
    I'm confident with our heat treating procedures, but throwing in the atmosphere component is confusing things. Anyone have any tips or advise on the subject?
    I'll add too that IMO there's no way around the bowing issue with these parts other than lots of stress relief in between operations, but It would be nice to see the atmosphere feature put to use.
    Jul 2006
    Hillsboro, New Hampshire
    9,967
    2315
    6969
    Couple things come to mind:
    1) Replacement of atmospheric gas takes a while, and argon's not free. How about using the stainless foil wraps, but with a stainless tube running into the wrap so it just purges where the part is?
    2) Set the foil packs vertically, blocking them in with insulation blocks to constrain them.
    3) Use pottery furniture (ceramic shapes) to brace the parts? I have "half moon" strips of Al2O3 that are ~1" x 1/2" x 12", could they sandwich a piece of your D2 and be constrained with a stainless wire overwrap? If you think that could work I'd be happy to send you a couple pieces to test for postage costs.
    Oct 2005
    18,885
    Vacuum furnace.
  4. Likes TDegenhart, Joe Miranda liked this post
    Jul 2006
    9,967
    2315
    6969
    Vacuum furnace.
    Wut? You set fire to a Shop Vac??
  6. Likes camscan liked this post
  7. #5
    Jan 2005
    Victoria, Texas, USA
    4,335
    2724
    1158
    Have you tried Nitrogen?
  8. #6
    Oct 2005
    18,885
    "fire starter" they are....
  9. #7
    Mar 2011
    Geneva Illinois USA
    6,465
    2842
    2551
    Send the parts to a reliable heat treater.
    Tom
  10. #8
    Feb 2011
    2,569
    2111
    1139
    Quote Originally Posted by 4GSR View Post
    Not yet but I've read it's cheaper so I plan to pick up a bottle. We had a few Argon bottles already for welding.
  11. Likes 4GSR liked this post
  12. #9
    Feb 2011
    2,569
    2111
    1139
    Quote Originally Posted by TDegenhart View Post
    Tom
    We've tried a few but none of them will do anything about the straightness issue. They'll harden the parts, but any fixturing involved with it is in our hands. We don't have issue hardening D2 in general, it's the specific elements of this part being narrow and flat that make's it troubling.
    I'll add too that we're trying to hit a price point with this piece. It's an expendable part on a machine that we can buy from an OEM manufacturer, but the cost is so high that our customers tend to avoid replacing it until the machines are trashed. We've successfully made them in the past, we're just trying to simplify the process.
  13. #10
    Feb 2011
    2,569
    2111
    1139
    Let me clarify that first, I'm trying to understand the controlled atmosphere heat treating process, and second how our oven can work with it.
    I'm trying to find where we bought the oven from to see what they say in the matter. No tags on it though other than for the control.
    Out of the box, the oven had a single gas inlet with a flow control regulator. We added some plumbing to connect it to a tank regulator.
  14. #11
    Mar 2017
    LATVIA
    604
    160
    314
    from my personal experience tig welding things using back purge, argon is heavier that air, so to purge the air you'd want really slow flow from the bottom towards the top, high flow will make the argon mix with air and the purge will take forever, there has to be an opening at the top to allow the air to escape, for a furnace, I'd guess the opening could be closed after few minutes
    I've seen people use a stainless box with a lid and a stainless tube running from the box the outside (inlet for the gas), so they wouldn't waste more argon than necessary
  15. Likes M.B. Naegle liked this post
  16. #12
    Oct 2005
    18,885
    Nitrogen should cost less. I know it's used in semi load qty's for basic shielding locally (explosion proof electricals, lead pot coverage, paint activator tanks, etc.)
  17. #13
    Mar 2011
    Geneva Illinois USA
    6,465
    2842
    2551
    Nitrogen has been discussed in the past here, with cautions about undesirable reactions to the nitrogen. Another problem is that unless you have a vacuum furnace, the refractory is saturated with air and moisture. Heating with drive those gases and vapors out but slowly as the heat penetrates the refractory. Most furnaces that are not vacuum enclosed the article to be HT'd in a coating or a sealed box. Depending on the size of the article, if you are going to do much HTing then it may be cheaper in the long run to get a vacuum furnace.
    Tom
  18. Likes Hightemp, sfriedberg liked this post
  19. #14
    Sep 2006
    SW Wisconsin
    611
    85
    185
    I made a SS tube with a tube running to the outside of the furnace much as jz79 describes running nitrogen, didn't work , got scale no matter what the volume of gas flow. Back to the bags. If someone makes it work please tell us!
    Ed.
  20. #15
    Oct 2005
    18,885
    Quote Originally Posted by atex57 View Post
    Ed.
    "retort furnace" is I believe what they are called.
    Neighbor's weld shop made one 20' long, 18" wide and 12" high, with end flanges, with gas connections....all from Inconel....parts travel thru the tunnel, heat is from the outside.
  21. #16
    Nov 2010
    Virginia
    131
    183
    23
    Tom
    Yeah, you can only get so good of an atmosphere with that sort of furnace purging. Maybe you could build a simple retort for a trial run? Like a stainless box with a couple of fittings for gas(and maybe a thermocouple)?
  22. #17
    Jan 2007
    Flushing/Flint, Michigan
    9,183
    503
    7619
    You were using CO2 for carburizing?
    The ones I ran did like that two on the end as it can literately suck the carbon out of the steel doing just the opposite of what you want.
    I hope you meant CO. For me any CO2 in the furnace meant a lot of scrap parts and an inquisition as to how I let this happen on my watch.
    Bob
  23. #18
    Oct 2016
    Florida
    380
    899
    239
    Have you contacted the steel supplier?
    I did a search and came up with
    High Speed Steel | D2 Steel | D2 Technical Data
    for D2 steel
    If you call the supplier and ask they can provide technical data for what you are wanting to do. The temperatures shown in the graphs are not insignificant numbers. I believe it would be important to track their requirements precisely.
    I also like the idea of the part being in a sleeve so the gas can be held to correct concentration. The sleeve has to be able to allow the temperature of the atmosphere in the oven to transfer quickly so perhaps choose a material to allow excellent temperature coupling between the sleeve and the part.
  24. #19
    Feb 2011
    2,569
    2111
    1139
    Bob
    We never got to, but I think your right it was CO we were going to try. We might revisit that process but I think the standard oil quenching or packing parts in case-hardening compound would produce the best results.
    A lot of our parts that previously called for case hardened mild steel have done better by making them out of air hardened tool steels. It's been a while since we've needed to case harden something.
  25. #20
    Feb 2011
    2,569
    2111
    1139
    I found the oven's original manufacturer, Paragon in Mesquite, TX. I'll get in touch with them and see if they have any ideas.
