Heat treating without foil?
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Jun 2017
    71
    7
    14
    Default Heat treating without foil?
    Is there any negative side effects of heat treating air hardening tool steels without wraping them other than scale?A2 and A6 specifically
    Oct 2010
    Oregon
    5,172
    4473
    1878
    In addition to scale, you may have softening of the surface due to decarburization. There was a thread here not to long ago about A2 parts that 1) looked oxidized, and 2) had a soft surface. Our collective best guess was exposure to O2 atmosphere during heat treat.
  3. Likes Hopefuldave liked this post
    Apr 2006
    Suffolk, England
    884
    95
    239
    Has anyone tried the old-fashioned soft soap method for preventing decarb?
    Over here in the UK, stainless foil bags or wrap are hard to come by - we can order some online, but they're shipped from the US or China.
    So, would soft soap work for onesy-twosy parts? And what is the 'right' sort of soft soap? There's is plenty available from places like pottery supply retailers.
    Oct 2005
    16,137
    Why not the old method of a steel plate box and bone or charcoal ?
    Or steel filings if you don't want to carburize.
    Aug 2004
    Virginia
    2,373
    178
    931
    I have used soap to heat treat in my forge and yes it does work.
    Sep 2005
    Michigan
    99
    9
    Default Roach poison
    I use powdered boric acid, sold as roach and ant killer. Heat the part up just a bit then dip it into the powder, which will stick to the hot part. When you continue to heat the part the boric acid turns into a thick liquid that coats the part. A water quench will cause the coating to crack and completely fall off. Oil quenching doesn’t always get rid of all of the coating, but what’s left is pretty easy to clean off.
    Easy, effective, cheap, and available.
    Dave
  8. Likes Scottl, Dumpster_diving liked this post
  9. #7
    Oct 2010
    Dewees Texas
    2,437
    28
    667
    Quote Originally Posted by DaveRobinson View Post
    Dave
    This has worked for me in treating small part made from W1 and such. For A2 and A6 I might be inclined to cover parts with boric acid which necessitates putting the parts and powder in a container, I have used one made of stainless foil for this. Parts made form A2 or A6 will be hot for a lot longer time and the boric acid may run off. Some metals such as 416 can be eaten up by the acid. Not sure why one metal is eaten up and another not. Try a sample first.
  10. #8
    Nov 2013
    Eastern Massachusetts, USA
    4,535
    4653
    4644
    Quote Originally Posted by Peter Neill View Post
    I've used that on water and oil hardening. Basically you want a quality soap of better make. If it can be used for hand washing and gradually wear down to a sliver without either cracking or turning to mush (which cheap soaps do) it should be suitable. You rub it on as soon as the steel is hot enough to leave a streak of soap.
  11. #9
    Jul 2006
    rochester, ny
    1,943
    401
    559
    When hardening A2, does the speed of cooling matter?
  12. #10
    Jun 2017
    71
    7
    14
    Quote Originally Posted by sfriedberg View Post
    I was afraid they would end up soft like that, guess I'm going to order some stainless foil, it's a pretty decent job but the parts are little less than a half inch square so didnt seem worth it to order 50 feet lol
  13. #11
    Jun 2017
    71
    7
    14
    Quote Originally Posted by richard newman View Post
    I think it's only critical to be exposed to oxygen from like 1800/1650
  14. #12
    Jun 2014
    Kansas City
    738
    102
    469
    Could you put the parts in a piece of pipe with caps on the end? Maybe put some paper in with the parts to burn up the oxygen?
  15. #13
    Oct 2014
    CANADA
    Ontario
    1,270
    754
    1041
    Yes it does, a lot! Oil quenching A2 will leave you with a piece so hard that it will be difficult to temper it back to something reasonable, the part will also have very low toughness and may crack during quenching. Water quenching A2 is just a big 'no no'.
    A2 quenching is best done by simply hanging the part in still air. Hanging is better than putting it on a flat surface as the side facing the surface will cool slower and the part will warp. If the part is big and needs support then cooling is on a steel mesh table is probably best.
    Avoid cooling the part with a fan or compressed air as again this will cause uneven cooling and warping.
    If you need to heat-treat without foil the simplest way I have found is to use an 'anti-scale' compound like ATP-641 from Brownells. This is basically a clay 'slip' (thin mixture of clay and water) that you apply to the part after thorough de-greasing. The clay dries on the part and forms a barrier. During the quench the clay will crack and spall off the surface, you do not need to oil quench to get it to crack. You can also clean up the final part by bead-blasting to remove any remaining clay without damaging the steel surface underneath.
    With all that said: heat-treating in foil will still get you a better result and a better looking part. Even better would be to seal up the outside of your furnace and then plumb it for inert gas like Argon. A small flow of argon during the heating process will drastically reduce or eliminate scale/decarb.
  16. #14
    Oct 2014
    CANADA
    Ontario
    1,270
    754
    1041
    Quote Originally Posted by Erstwhile View Post
    Any temperature over 400ºF will start growing an oxide layer on the part. Any temperature over about 900ºF will start causing decarburization/scale (albeit slowly at first). Best thing is to protect the part the whole way through the heating/quenching process.
  17. #15
    Mar 2005
    Kansas
    7,639
    440
    3543
    But don't use the anti-scale in an electric furnace.
  18. #16
    May 2012
    Pittsford, NY
    1,055
    726
    680
    Gbent, can you explain?
  19. #17
    Oct 2014
    CANADA
    Ontario
    1,270
    754
    1041
    Quote Originally Posted by gbent View Post
    I have done this many times without issue.
  20. Likes Hopefuldave liked this post
  21. #18
    Aug 2004
    Virginia
    2,373
    178
    931
    I think what Gbent is referring to is when you use boric acid in an electric furnace, it runs down on the bottom and soaks into the firebrick. It is almost impossible to remove. Been there done that.
  22. #19
    Feb 2001
    Redwood City, CA USA
    5,007
    187
    925
    Quote Originally Posted by crossthread View Post
    The borax fumes also attach the elements. BTDT.
  23. #20
    Oct 2014
    CANADA
    Ontario
    1,270
    754
    1041
    Gotcha, makes sense. The anti scale I mentioned (ATP641) is not borax based and is fine to use in an electric furnace. ATP641 from Brownells has worked well for me many times in an electric furnace with no noticeable ill effects on my furnace!
