blueboy
- Dec 15, 2015
- Pittsburgh
If I had a 1,000 watt hot water tank heating element and wanted to reduce it to around 700, how would I do that?
why? is there no thermostat or timer?
look for "4000w scr" on ebay for $4.
I think that will work. Thanks!
It’s for an OLD water distiller. Can’t get the correct heating element so I have to improvise. A standard hot water tank element (adapted to fit) works but it burns out after it makes about 15 gallons. So if I can reduce the voltage just enough to boil the water it should extend its life.
Thanks guys, keep up the good work!
Sounds shocking...and now it finally comes out.
Just doo what the simple room vaporizers doo....put the wall electricity directly into the water.
NO elements to overheat or "burn out".
Sounds shocking
All stainless steel.
How many keystrokes now? LOL
edit: the link still doesnt work.
Those humidifiers that run current directly into the water generate both hydrogen and oxygen. I had a small immersion heater that worked on the same principle. you could light the bubbles.
To find the right voltage for a specific wattage: W=V^2/R.
The problem with trying to use that formula is that the element resistance varies with temperature and that varies with applied voltage.
They doo not. they run on a.c.
Unless you, or someone else put a diode in series for "half power"....
Notice
