Erich
Hot Rolled
- Apr 4, 2017
- Poway, CA (from Location field)
Hello all, this is my first post. I hope I am placing this in the correct subforum.
I have the above mentioned mill. My wife's grandfather bought in new in Feb. 1957. Serial # is MV175
I have had the beast for nigh on twenty years but I have not used it a lot. Something about raising children, but I digress.
It is missing a couple of parts and I would like to get some key dimensions so I can make the parts myself.
I am missing the wheel and o ring that spins the rpm meter on the front of the mill.
part numbers are mv 80134 and mv 80136
for the o ring what is the section diameter and OD or ID
For the wheel what is the OD, bore diameter and overall thickness.
Is the bore stepped or straight thru ? Material? I assume aluminum.
The other missing piece is part of the power feed clutch assy part number mv 80156. There are two of these parts. They are probably brass and they are shoe that runs in the groove of the engagement clutch.
They transmit the motion from the knob that hangs under the left side of the head that engages the clutch to the auxiliary timing pulley.
It looks like they could just be a length of 1/4 inch square stock with a side hole drilled for a dog point set screw to fit in.
If anybody could confirm that and give me an overall length of the part I would be grateful.
