I don't really know anything about machining, so keep that in mind. I can fix my own car, cut wood enough to get by and that's it. I'm always open to learning though!
My grandfather who has dementia has basically left me a garage full of tools. He liked to amass things, and while looking through it all, I came across a large set of taps and dies as well as what looks like some heavy duty metal drill bits and some things that I can't readily identify, but look like block-shaped taps or drill bits. It has been sitting in a box for years, if not decades.
I don't know if he actually knew how to use all of this and he doesn't have a machine for them, outside of a regular drill press. They're probably about 20-30 years old and have some rust, but I think they started out as quality industrial tools. He worked at the EMD division of General Motors for many years refurbishing locomotives, and when the plant closed, he bought a lot of their equipment and it's all built like a battleship.
I'd like to know the following, if possible...feel free to point me to another thread if you like:
1) Is this equipment particularly valuable or is it junk? I know that's hard to tell from the pictures, but your best guess will be fine.
2) Would rust dull it and make it less useful? Does it need to be cleaned up before use? If so, what's the best way to do so?
3) What would this allow me to do in terms of machining and what additional equipment would I need to get started?
Sorry for the quality of the images, but there's not much room to spread out as the garage is still a big mess. The taps in the third image are much larger than the ones in the pile photo so I took them separately. I should have put a tape measure in for scale.
Thanks in advance!
Thanks in advance!
