Good evening PM,
I work for a tree service and we generally use our crane for tree work, or setting trusses for some of the local construction companies. We have moved some machines in the past, but that was just to bin them for scrap (I shed a tear for a few, I can't deny), however tomorrow I need to lift a MSZ EE-630-01 onto a trailer, and then off again at the destination. I don't want to write off the lathe by damaging the ways, lead screw, or anything else on the machine.
I've watched Adam's video on lifting, and have looked at the images provided on a few of the threads here in the past. If I can't find any specific information regarding the lathe I need to lift then I will do my best to follow their lead, by blocking it to keep the slings off of the precision parts and have all of the load placed under the bed.
Is there any reason why the lathe I am lifting should be treated differently, or perhaps do the MSZ lathes have dedicated lifting points?
If all goes according to plan, we will be lifting the lathe straight up, backing a flat bed under it, and then placing it back down.
Thank you for your time,
Shaun
Shaun
