HELP! Bizarre Rust On Machine and Tools
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Sep 2021
    Ohio
    34
    Default HELP! Bizarre Rust On Machine and Tools
    New user here, just starting out in the amazing world of machining.
    Background
    -We create proof-of-concept prototype hardware and have a small, but very capable shop that we keep meticulous not only for good housekeeping practices, but because of risk of cross-contamination.
    -We never had any issues with rust of any kind.
    Challenge
    Recently, we had to create sleeve bearings using C932 Bearing Bronze and used the lathe, mill, drill, and bandsaw in their creation.
    Almost instantly, we noticed rust where we handled previously non-rusting surfaces (see attachments)
    Nothing seems to remove it- we have tried Acetone, Alcohol, WD40, Silicon, lubricating oil, to no effect. The Silicon spray works temporarily, but ultimately the rust comes back.
    I do not know where to go, have researched on the "interwebs" for hours, and have found nothing to help.
    Any/all assistance or guidance would be much appreciated.
    Thank you!
    Attached Thumbnails Attached Thumbnails lathe-chuck.jpg   table.jpg   vise.jpg   ls-drill-press.jpg   rs-drill-press.jpg
    Oct 2009
    Olympia, Wa
    798
    344
    253
    looks like the same rust I get on machine tools in my unheated, insulated shop. steel wool and wd40 should take it off, just wipe a light film of oil of the tools after you clean them up
  3. Likes progeny liked this post
    Aug 2017
    359
    99
    176
    Do you have any hydrochloric / muriatic acid in your shop?
    Dec 2012
    AUSTRALIA
    4,837
    29
    1747
    I think the brown is bronze powder.....incidentally ,bronze "needles" have a reputation of creating havoc in your laundry ....legendary tales of wives and children being "stung" by bronze needles in the washing.......copper and bronze dust will also electroplate brown onto iron just by the moisture in the air....Machines from the bronze shop always had a marvellous brown patina .
  6. Likes progeny liked this post
  7. #5
    Jul 2006
    Hillsboro, New Hampshire
    14,136
    3091
    9369
    If nothing else works, try scrubbing a test area with a mild alkaline solution and a fine Scotch-Brite, then wipe dry and cover with a preservative oil. See if this improves the test area, if so use it more broadly.
    Alkaline Cleaning Guide | Products Finishing
  8. Likes progeny liked this post
  9. #6
    Mar 2005
    Kansas
    8,726
    625
    4441
    Somebody there has piss hands. Body chemistry makes steel rust. Use more oil, keep everything oiled. Cleaning with acetone makes it worse, as it removes the oil.
  10. #7
    May 2009
    Canandaigua, NY, USA
    3,415
    178
    1733
    Oiled grey Scotchbrite works well on that sort of thing.
  11. Likes progeny liked this post
  12. #8
    Nov 2015
    Oklahoma
    379
    85
    166
    "Instantly" meaning like overnight? Any new chemical processes going on near by?
    We had a machine shop next to a plating area. Occasionally when machine shop 1st shift came in all the machines, tools, etc would have a light coating of rust. We determined the plating area was doing something over night that caused some kind of acid gas to form that was getting blown thru the machine shop by the shop fans.
  13. Likes progeny liked this post
  14. #9
    Sep 2016
    Missouri
    1,206
    999
    404
    You should look for what's causing the problem but there are products like the one in the link below that protect bare metal from rusting. An aerosol can is about ten bucks in an automotive parts store or order a gallon online for about $45. The gallon lasts forever just brushing or wiping on a light coat.
    It works
    Fluid Film® Product Family | Fluid Film (fluid-film.com)
    fluid film - Bing
  15. Likes progeny, Pathogen liked this post
  16. #10
    Feb 2009
    Oz
    397
    19
    85
    I see this on some of my iron and suspect acid chemical contamination from some of the things I do in the same area. I use scotchbrite and oil to clean it up, but I don't go back to bright and only remove the loose stuff. This leaves a mildly protective surface like the old rust blueing used before chemical blues became available.
  17. Likes progeny liked this post
  18. #11
    Jul 2015
    Michigan
    85
    112
    39
    CorrosionX. I get it in the aerosol cans so it sprays as you'd expect. If you get jugs of the stuff you'll need one of their spray systems, because it's viscosity / makeup is formulated for pressure spraying.
    We found taperlocks sealed in plastic product bags that had splotches of rust on them. No one could explain how that happened. Bottom line: Taper Locks get a fast & light spray of CorrosionX before sealing in a bag.
  19. Likes progeny liked this post
  20. #12
    Jul 2019
    Connecticut
    34
    64
    10
    Try any new cutting oil or tapping lube lately? I tried a new brand of lube and was drilling holes on my bridgeport, the next morning when I came in, the face of the brideport quill, the collet, vise, and parallels all had a brown rust on them. I'm sure this is a well known occurrence with certain lubricant properties but it was my first time seeing it happen.
  21. Likes progeny liked this post
  22. #13
    Nov 2012
    Connecticut
    171
    5
    38
    Looks like some of the Machines in my shop after an employee decided to sanitize them, judging by the location of the rust, it looks more like where someone would put there hands.
  23. #14
    Jul 2001
    North Carolina
    2,227
    261
    558
    The company where I work started having an outside janitorial service
    start spraying some chemical the CDC came up with (no msds sheet, gee
    thanks). It is supposed to kill covid virus. They walk around after hours like a bug exterminator, spraying work benches, machines, desks in the office, everything. So now all the steel benches and machine tools
    are rusting. Best I can tell it is some kind of bleach, what is that,
    sodium hydroxide?? I can't do any more asking about a msds sheet, because then I will be labeled as a non team player with the cooperate culture we have around here. Even parts on the engineers desks are rusting. I think they are spraying my coffee cup. Probably my nuts are going to fall off. But at least I won't get covid. Are you spraying for covid at night???? Or like mentioned before, someone has piss hands.
    --Doozer
  24. Likes 4GSR, progeny, dalmatiangirl61 liked this post
  25. #15
    Jun 2018
    New Mexico
    190
    262
    86
    We had a draftsman at the company I worked at 50 years ago with hands that left rust on anything he touched. He was a good draftsman but wasn't allowed in the shop. :-)
    ...lewie...
  26. Likes progeny liked this post
  27. #16
    Jul 2004
    Reddington, N.J., U.S.A.
    3,694
    744
    471
    Are you maintaining a low relative humidity in the shop?
  28. Likes 4GSR, progeny, Mtndew, neilho liked this post
  29. #17
    Nov 2008
    2,769
    21
    734
    Mix light oil with solvent about 10 to 1 solvent to oil.
    Spray this on your bare metal and wipe down with clean rag to insure everything coated.
    Solvent evaporates and leaves a thin oil film.
    Oil dependent on limitations of your work area.
    Sent from my SM-G781V using Tapatalk
  30. Likes progeny liked this post
  31. #18
    Feb 2007
    St. George, Utah
    1,430
    954
    1000
    Quote Originally Posted by Doozer View Post
    . . .it is some kind of bleach, what is that, sodium hydroxide?? . . .--Doozer
    No, bleach is sodium hypochlorite. Sodium hydroxide doesn't generally cause rust in the hot-tanks, etc.
  32. Likes progeny liked this post
  33. #19
    Dec 2016
    Colorado
    78
    20
    51
    Is there anyone now there that enjoys and adds a lot of salt to their foods. Back when I would add salt to almost everything I would refuse to handle other peoples metal items. They would rust after I touched them.
    Thank you,
    Mr.Smith
  34. Likes progeny liked this post
  35. #20
    Sep 2021
    Ohio
    34
    WOW-thank you so much for all the replies!
    To answer some of the questions:
    - We have various, but limited people in the lab area
    - Other than the bronze material itself, no new/different fluids or vapors have been introduced, nor are there any other processes nearby
    - The area is insulated and environmentally stable (constant temperature and humidity control)
    I will post update(s) as/when found.
    Again, thank you so much for your suggestions and feedback.
    Scott
  36. Likes Mtndew liked this post
