Anthony3076
- Jul 17, 2018
I've run into a situation that I haven't really been in before and would really appreciate the help with finding a tool that I could use for this job. I need to bore a 6" hole through a 3" thick, 24" diameter S.S. circular flange. Normally this would be something I would do on the lathe but because the hole is offset from the center I have to do it on the mill instead. I have a prototrak DPM2 conversational mill with R8 collet, so basic cnc operations are easy, but my dilemma is finding a tool i can use to get through the 3" depth. My first thought was to use an index-able end-mill;However, I haven't used index-able end mills much, so I'm not sure they would have the reach to cut through the piece. I don't want to spend ungodly amounts of money on a new tool because its only two pieces and I won't have to do this again for a long time. Any input on tooling would be greatly appreciated and if its not too much to ask, a link to the tooling you recommend would be fantastic as i'm not too experienced with a lot of the index-able cutters.
Thank you for your help,
Anthony
Anthony
