Help choosing a mini lathe
Results 1 to 11 of 11
    Apr 2019
    Washington
    25
    Default Help choosing a mini lathe
    I am trying to decide on a decent mini lathe to get. I require:
    (1) Customer service/parts availability
    (2) Dual direction rotation
    (3) Fairly precise stock chuck
    What I am grinding is graphite, so a 3/4 HP motor should be fine as I don't need the torque. Our manufacturing process requires the motor to run at low speeds for 10 minute intervals with a 1 minute break between intervals. It would be handy if I could get accessories for it (such as milling bed attachment), but not necessary. I am trying to spend about $1000, so my options are fairly limited. What I do not want is to buy "more machine than I need". I do not want something with a large footprint. I only need a 6" swing and about 12" between centers. Does anyone have any recommendations?
    Thanks for reading!
    Feb 2013
    North Carolina
    424
    540
    162
    This Sheldon looks pretty good:
    12” Atlas lathe, Quick Change gear, taper & milling attachments, 3 /4 Jaw chucks | eBay
    Despite the A-word, its actually a Sheldon.
    May 2017
    Massachusetts
    375
    403
    189
    Try posting this instead:
    Our commercial manufacturing process involves shaping graphite. I have a $1,000 budget for a new machine and require: 1) Customer service/parts availability, 2) Dual direction rotation, 3) Fairly precise stock chuck.
    Perhaps a 3/4 HP motor should be fine as I don't need the torque. Motor will typically be run at low speeds for 10 minute intervals with a 1 minute break between intervals. It would be handy if I could get accessories for it (such as milling bed attachment), but not necessary.
    My options seem fairly limited but I do not want is to buy "more machine than I need". I do not want something with a large footprint. I only need a 6" swing and about 12" between centers.
    Apr 2019
    Washington
    25
    Thanks Cranium. Unfortunately I was looking for something with a smaller footprint. I have a SEW Eurodrive motor with a MOVIMOT inverter capable of a wide variety of speeds all the way to zero, eliminating the need for gears(less parts to break, easy PLC control). I may just buy spindle/tailstock and use my linear actuators(also easy PLC control) as the bed. As nice as it would be to have this degree of automation, I was hoping to find something that I would not have to spend an entire week wiring and programming. That Sheldon DOES look good though!
    Jan 2005
    Houston
    5,868
    583
    2677
    Have you considered making your own lathe? Perhaps fabricated of aluminum plate, even,?
  6. Likes digger doug liked this post
    Oct 2005
    16,595
    Quote Originally Posted by GregSY View Post
    Get with the times Greg...."composite" is the new way.
    Driveway gravel, Bondo, and a HF mini cement mixer.
    Add Mach3 and your all set.
  8. Likes GregSY, mike 44 liked this post
  9. #7
    Aug 2004
    Virginia
    2,406
    179
    953
    What about a 9" South Bend. You can pick up a fairly nice and very usable one around here for well under $1K. If I remember they came with a 3/4 HP motor installed.
  10. #8
    Jun 2012
    Michigan
    10,487
    3568
    3736
    You don't tell part size or actions need to be cut. But a little bigger than a mini like a decent 8, 9 or 10-24 lathe gives a little more room for dust containment, bigger hand wheels, greater selection of holding device and yet takes little more room/bench space.
    Wade 8" x 24" Tool Room Lathe, Model. 8A | eBay
    Agree some likely over $1,000 but likely better chance of getting your money back at selling time.
    Agree that A...s - Sheldon looks like a great deal. again easy to get you money back at selling.Way too far away to ship to Washington.
  11. #9
    Oct 2012
    NE Ohio USA
    633
    126
    235
    Quote Originally Posted by cranium View Post
    Sorry. That is not a Sheldon.
    Best Regards,
    Bob
  12. #10
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,313
    1266
    714
    Quote Originally Posted by rjs44032 View Post
    Best Regards,
    Bob
    So what the heck is it? I see tags indicate [email protected], but it has prismatic ways??????????
  13. #11
    Oct 2012
    NE Ohio USA
    633
    126
    235
    Quote Originally Posted by dalmatiangirl61 View Post
    Most likely Atlas/Clausing
    Look Here: Clausing 12-inch Models 100 & 200 lathes
    Scroll down that page to the Mk.3 info. You'll see pics of it there. Hope this helps.
    Best Regards,
    Bob
  14. Likes dalmatiangirl61 liked this post
