Help..Custom tool source: 10mm spot face with .159 drill
Results 1 to 7 of 7
    Jan 2012
    st louis
    261
    34
    22
    Default Help..Custom tool source: 10mm spot face with .159 drill
    Hi PM
    Im looking for a tool that would allow me to tap drill 10-32 (.159") and also create a .4 or 10mm spot face.
    The hole is going radially in a diameter and Im trying to run it in a live tooling lathe. I dont have enough live holders to do all the operations I need and this tool would make it doable.
    Should I be looking at a custom tooling place or has someone seen a spotface or counterbore that can be added to a drill bit?
    Matt
    Jan 2007
    Norfolk, UK
    19,280
    14737
    14891
    I'd say custom grind - 1 piece tools are more reliable.
    BUT ………………….
    Can you not use an off the shelf 5/32 2 flute end mill to drill and interpolate the hole then do the spot face?
    Sep 2004
    Sonora , Calif
    586
    120
    124
    Step drills unlimited
    Downey Ca .
    Google them.
  4. Likes matthewlee liked this post
    Jan 2012
    st louis
    261
    34
    22
    I am using a C-axis machine. Interpolation is out.
    Quote Originally Posted by Limy Sami View Post
    BUT ………………….
  6. Likes Limy Sami liked this post
  7. #5
    Jun 2012
    Tennessee USA
    785
    462
    464
    I would think (but don't know for sure) that in the greater St. Louis area there should be a few companies willing to make step drills for your application. I worked for Spiral Step Tool (Chicago area) in the 1980's and that was a regular part of their standard product line. Somebody with a surface grinder and/or a T&C grinder could do this with a 13/32 stub drill (less flex) without too much trouble. I've made step drills/spot face now and then for similar applications. A good tool grinder hand could even include the c'sink on the same drill, eliminating the extra operation (although more expensive). It's all about quantity, cost, and savings. Hope this helped.
  8. Likes matthewlee liked this post
  9. #6
    Sep 2015
    Ohio
    1,225
    797
    1226
    How about a c'bore with interchangeable pilot?
    https://www.mscdirect.com/product/details/65706368
    1/8" pilot hole, spin down a screw machine length .159 drill?
  10. Likes matthewlee, Limy Sami liked this post
  11. #7
    Feb 2014
    Sunny South West Florida, USA
    3,082
    11102
    3477
    MITGI.US
    They'll make a sweet custom in a week or two. Great for repeat jobs.
  12. Likes matthewlee liked this post
