Help with deep, blind hole boring
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jul 2021
    Montana
    10
    Default Help with deep, blind hole boring
    All,
    I need to put a blind hole 12Ē deep x 1.35Ē diameter in 6Al-4V Titanium bar stock. I need the bottom of the hole to be flat. My first thought was use a ~1.25Ē gun drill to establish the hole, then bring it to size with a boring bar, which would get me the flat bottom as well. The issue Iím having is finding a bar that will reach that deep but requires a small enough minimum hole size to fit. Anyone have any experience with this type of scenario? FYI: Iím a hobbyist with access to the gun drill, but Iím on my own for the bar, so I donít want to drop a ton of money on it. Any insight would be appreciated. Thanks!
    Mar 2005
    Kansas
    8,789
    630
    4518
    If all you need to do is square up the bottom of the hole make a flat bottom drill bit.
  3. Likes Booze Daily, Ray Behner liked this post
    Jul 2021
    Montana
    10
    Noted. Thanks for the insight. Any thoughts on the best way I can bring the hole to size? I thought about buying a used 1Ēx12Ē indexable heavy metal bar on eBay, then just adding an extension to it to get the depth I need.
    Apr 2018
    9,792
    4705
    12" deep 1" hole with a flat bottom in Ti ? Can you retire early instead ?
    This is gonna be a bitch
    (They make flat bottom inserts for spade drills but I dunno, maybe. At least you could pump a bunch of coolant in that way.)
  6. Likes tylersteez, AlfaGTA, eKretz liked this post
  7. #5
    Oct 2005
    22,783
    Quote Originally Posted by TGraves3 View Post
    Noted. Thanks for the insight. Any thoughts on the best way I can bring the hole to size? I thought about buying a used 1”x12” indexable heavy metal bar on eBay, then just adding an extension to it to get the depth I need.
    What is your tolerance on that "final size" ????
  8. #6
    May 2010
    Cambridge, MA
    1,871
    83
    1093
    To make the bottom flat, you can make a tool called a "D-bit" which is just a cylinder with a chamfer through the diameter. To bring to size you can use a cylinder hone.
    Engine rebuild shops are experts at this stuff because they rebore cylinders all the time and they can probably do it pretty cheaply.
  9. Likes neanderthal mach liked this post
  10. #7
    Dec 2002
    Benicia California USA
    8,878
    2346
    3282
    Quote Originally Posted by jscpm View Post
    Don't waste your time! Engine shops almost never hone to a blind hole, They are in general piss poor at doing while keeping the bore straight....They are familiar with honing where the stones can pass outside the end of the bore, not stop at a hard shoulder or step.
    We run into this all the time on engine blocks that have blind cylinder bores (Offy, Bugatti, Miller, Alfa etc.)
    Also almost always a blind cylinder bore has a relief between the chamber and the top of the bore, so they never hone to a hard stop at the end of the bore....
    To go further...Rarely will an engine shop have a 1 3/8" hone mandrel that can reach 12 " in length....its not a size they would need or use.
    Can you tell us what machines you are planning to use here...Is this a turning or mill application...
    Manual or CNC capibility?
    Cheers Ross
  11. Likes Ray Behner, sfriedberg, tdmidget liked this post
  12. #8
    Jul 2021
    Montana
    10
    Tolerance is +/- .002Ē. Itís a manual lathe. I thought about the hone, but Iím with Alfa, I donít think I could pull that off. I would be fine with just gun drilling, squaring up the bottom, and calling it good; but, I know the drill will walk. There is a hole in the blind end that needs to be concentric with the bore, hence the need for a boring bar to achieve that. Thatís what makes sense in my mind, at least?
  13. #9
    Jun 2013
    491
    399
    213
    Quote Originally Posted by AlfaGTA View Post
    Cheers Ross
    Nothing here so far has suggested the need for honing. Should be able to achieve this with a boring bar.
  14. #10
    Feb 2020
    Maryland
    302
    120
    If the hole at the blind end has a reasonable size you can put a shaft through, you could make up a line boring jig to get it perfect.
  15. #11
    Jul 2021
    Montana
    10
    Hole in blind hole end is .625Ē. I didnít think about a line bore setupÖ Iíve never done it. But, thereís a first time for everything I guess!
  16. #12
    Mar 2005
    Kansas
    8,789
    630
    4518
    What other features are you going to throw at us? Now you tell us its not a blind hole, but a small but unknown diameter hole with a 1.35 diameter counterbore 12" deep.
  17. Likes Garwood, digger doug liked this post
  18. #13
    Oct 2009
    Oregon
    6,611
    7045
    3922
    Hole in blind hole end is .625”.
    Read that a couple times and let it sink in.
  19. Likes TeachMePlease, tylersteez, tdmidget liked this post
  20. #14
    Mar 2005
    Kansas
    8,789
    630
    4518
    Ok, missed the late 5/8. Gun drill the 5/8 and counterbore the 1.35. Far different, far easier problem than 1.35 blind hole 12 deep.
  21. #15
    Oct 2010
    Oregon
    5,875
    5886
    2283
    TGraves3, do you just need a shoulder 12" below surface level? If so, consider a through hole/bore with a groove at the right place for a suitably stout retaining ring. I like Smalley spiral rings (or competing products) for things like this, and it's a dirt simple job to make an installation tool. Just get the groove width and depth correct. Engineering data, including load ratings, in the Smalley catalog.
  22. #16
    Oct 2005
    22,783
    What manual lathe ?
  23. #17
    Mar 2009
    Brunswick Oh USA
    4,811
    5728
    2926
    Can you drill through entire piece and plug the ass end with a 1.350 x .625 plug.
  24. Likes sfriedberg liked this post
  25. #18
    Nov 2020
    Alabama
    98
    35
    58
    I’ve been doing similar work in 17-4 on a manual.
    I drill with an extra long amec spade to .050” under final ID. I’ve done a flat bottom by drilling a preliminary hole .75” shy of final depth and then swapping to the flat bottom to finish out.
    I bought a .75”x13.5” carbide blank on eBay (you have to dig but you can find them for under $100) and ground a tip on it. When I got tired of touching that up I grafted on an indexable head. At that depth you will be much happier with a carbide shank. I’ve worked at 12xD with that bar going suuuuuper slow and taking little cuts. It helps to hone a super fine edge on the insert and use a little oil.
    After the spade work is done I do finish passes with the boring bar until complete. If you are going to thread the wide mouth end then do it in the same setup.
    Once you finish that up you would flip and then make your threads as required.
    You can do it, im a hobby guy too. Plenty of archived knowledge on here to put it all together. It took me a while to figure everything out.
  26. #19
    Nov 2020
    Alabama
    98
    35
    58
    Here is the insert i grafted on. You could obviously buy a ready-made solution but in my case that would cost more than my lathe did...DIY it is
    Here is a shot down the bore (not a great pic). When you transition from normal spade point to flat bottom you will get some chatter. Just take it slow. You could probably drill the whole thing with the flat bit but i didn't. This one had an internal step towards the rear that had to be brought to a different ID than the front part.
    Here is the XL spade drill mounted on the compound. I tried the tailstock and it was a pain in the ass to keep cranking. This is good enough. Eventually i will block mount it directly to the compound vs a tool holder. Just tighten everything up real snug if you go this route. Ask me how i figured that out....
  27. Likes ezduzit, Kiwi2wheels liked this post
  28. #20
    Jul 2021
    Montana
    10
    Itís a Mori Seiki 850. Thought about going the plug route, but I like the one-piece concept for added strength; no joints to worry about. FJsapper, thank you for insight. Iíve been trying to find a solid carbide blank to just grind my own geometry into, but I canít find one long enough. Would need at least 16Ē or so to get the depth I need and have an adequate amount of surface area in the holder. For some reason nobody makes anything longer than 13ĒÖ from what Iíve found.
  29. Likes FJsapper liked this post
