One of my upcoming projects will require a small vacuum reservoir. I'd like to build it from 303/316 round stock (O-ring gasketed end caps) and polycarbonate tube stock. How might I go about calculating the minimum wall thickness needed to construct a safe and reliable vacuum receiver?
Thanks.
See prior cautions. Simply don't USE a "plastic" that is not
already proven in long, tough, use. DIY is best in all-metal, rather.
Custom-built vacuum reservoir? Why? You the first guy in the history of mankind to need one?
Common item, parts channels, auto industry. Made in the
multiple tens of millions. Every year. And about ten bucks, even on Amazon:
But one example of MANY:
Vacuum Reservoir | 47076 | Vacuum Storage Canister | Dorman Products
Size is an issue? Shape?
Next fastest and cheapest is to adopt one of the far more common
pressure tanks. Most will do max 1 BAR, gage, negative direction just fine. Many liquid FUEL tanks will do so as well.
Available sizes are all over the lot, new and used. So is metal tubing.
Think aircraft breathing Oxygen, common air suspension reservoirs, LESS common "jumping" trick-car air tanks, heavy truck air brakes, air-horns, paint-pot pressure tanks, air compressors.... "etc".
Steel. Aluminium. Stainless steel.
Copper, even. See "header" or "expansion" tanks, water-heater safety. Cap a length of ignorant but costly (and durable) Copper DWV line.
Otherwise one can find treated, coated."whatever".
Fittings usually included.
Why re-invent a cheap wheel when you have OTHER s**t to do that is harder to "just buy" and needs YOUR best-efforts .... or doesn't get DONE
at all?
Especially with "plastic" a known sub-optimal choice for low-maintenance longevity?
Leverage
your time onto the "critical path".
More
time cannot BE "bought".
2CW
