SanderBash
- Oct 10, 2018
Hi everyone,
Since this is my first post, let me quickly introduce myself:
My name is Sander, I'm from the Netherlands. I've almost finished my Masters degree in Molecular Life Sciences and am starting a PhD in Nuclear Magnetic Resonance, or NMR(akin to MRI). In my spare time I like to do woodworking and some light metalworking.
So, I have a question. In NMR we make use of very strong magnetic fields. Sometimes I need use slotted screwdrivers on the equipment, which obviously need to be non- magnetic.
Just for fun, I thought it would be a nice project to make some non-magnetic slotted screwdrivers. I was thinking to use roundstock and hammer the heads to shape, to work harden them a bit. Then the final form will be made by filing, sanding and maybe using some stones. I will turn some handles on a wood lathe.
But now the question: What material to use? I was thinking about brass, titanium or bronze, but there are so many alloys of these materials. Most screws in NMR equipment will be brass,sometimes stainless steel. What material would you suggest that is a good compromise between cost and performance? Ideally the material could be hardened, by work hardening or a very simple heat treatment. I hope someone can send me in the right direction
