Help figuring out which insert for Facemill
Results 1 to 7 of 7
    Jun 2003
    New York State
    750
    44
    74
    Default Help figuring out which insert for Facemill
    Hi All, I've acquired a pair of face mills that would be useful to have running for me, but it all seems greek to me as to what insert to use.
    The First is a Mitsubishi that is in immaculate condition. I can't tell if it takes a round insert (trying to judge by the pocket) Google is less than helpful. The number on it is SG20R0506E.
    The second is an older VR/Wesson. Number on it is FHR6-9004-5. It had an insert with it that is a parallelogram.
    Pics attached to help
    Any ideas?
    Peter
    Jan 2010
    Canada
    305
    60
    159
    Inserts are RPMX12 (probably)
    Jeff
    Mar 2018
    Wisconsin
    42
    12
    12
    We have an old Mitsu facemill like that(SE445...) , it takes SEHN 1203 inserts , 1/2 square x .125 thickness and I think 7º relief . Yours may need 1604 size depending on pocket dimensions .
    Jun 2003
    New York State
    750
    44
    74
    I found this page- translated from portugese! Looks like Jeff is onto the insert. I don't fully understand all the numbers/ letters. I think the R is Round and the P is positive. Not sure on the numbers as much
    Google Translate
    Jan 2007
    Flushing/Flint, Michigan
    7,142
    329
    5845
    The SG20R0506E takes a RGEN2004SN insert.
    Very special.
    .787 IC round, 3/16 thick, 30 degree positive.
    The lead milling cutter designer from Mitsu at this time was very much a leader into the high shear world so special insets often used.
    A P or an E clearance angle insert will not work.
    The Wesson FHR-9004 takes a MEC-632.
    A 86 degree parallelogram, 20 degree positive .750 IC, 3/16 thick, 1/32 rad on two corners, also a sort of special.
    A nice cutter body in that the cam pin allows you to adjust the insert heights so that you can set one intentionally proud or tweak them all the same.
    Limited sources, supply and grade selections on both inserts.
    Bob
  6. Likes crzypete, Matt_Maguire liked this post
    Jun 2003
    New York State
    750
    44
    74
    Thanks Bob, that is awesome info.
    Do you have any idea how the Mitsubishi will perform should I fork over the cash to find the inserts? Is it intended for specific metal? I want to run it on an older Manual Cincinnati mill with powered overarm. CAT 50, but max speed of around 1000.
    Peter
    Jan 2010
    Canada
    305
    60
    159
    This is the inserts you need. RGEN2004
    Mitsubishi Rgen24msn Uti2t Carbide Milling Inserts, Qty 1 | eBay
    Jeff
  9. Likes crzypete liked this post
