1richgilbert
- Jun 10, 2020
Hello, I’m looking for some advice on machines or tools to put external threads on 3-6mm brass rods.
We’re a furniture workshop who make all their furniture from CNC plywood. We want to including brass rod as a new material in the workshop to make bent metal parts, mostly brackets. I want to find a way to thread brass rods (most likely 3 - 6mm). Ideally it would be a fast setup to minimise labour time and probably batching 50-100 units at a time.
Most solutions seem to be for a lathe, we don’t currently have a lathe in the workshop and I’m not sure if its the right solution for us as we the setup could be too slow.
I’ve seen bike spoke threading machines which look close to the right solution but the diameter is too small and they might be a bit slow.
Cyclo Spoke Thread Rolling Tool for 12g 13g & 14g (rollers available separately) Simply Bearings Ltd
There are pipe threading machines but the diameters are too large.
Could anyone recommend any dedicated threading machines or tools for relatively low volumes? Any advice would be greatly appreciated
Best
Rich
Best
Rich
