Help finding octagon socket
Results 1 to 15 of 15
    Apr 2011
    VA
    57
    7
    Default Help finding octagon socket
    I am looking for a 1/2" x 1 1/8" deep socket (2") with a octagon/lock nut/ hub style pattern. This is for installing pipe couplings with octagon wrenching flats in a very tight access location. Anyone know where such a tool can be found?
    Apr 2004
    Modesto, CA USA
    6,079
    923
    In my limited experience square sockets are really octagons. But where to find square sockets these days? I think they are called eight point sockets.
    Bill D.
    Jul 2010
    Nebraska USA
    16
    6
    A square socket usually has 16 sides, rather than 8.
    Apr 2008
    Helmer, Indiana, USA
    1,189
    257
    470
    Use the connecting pipe to install the coupling?
    Machine a hex in place of the octagon?
    These suggestions may be of no help.
    Oct 2011
    Iowa, USA
    17
    when all else fails, look on ebay
    http://www.ebay.com/itm/Armstrong-21...item2eb60514df
    Apr 2011
    VA
    57
    7
    Thanks guys, but a traditional 8 point socket will not work for an octagon. Need something similar to this: http://www.ebay.com/itm/Spindle-Lock...a#ht_500wt_922
    Kyle, it is PVC coupling (female to male adapter) and the threaded side is at the bottom of the assembly, slip joint needs to be left unglued so I can't use the connecting pipe to tighten.
    Feb 2006
    SW PA
    6,024
    1266
    728
    Are you speaking of lying on your back in a vanity in a cramped powder room?
    If so, you are not looking for an "octagon socket", you need a "basin wrench". It ratchets, in a way, just as a pipe wrench gets a new bite. If not, ignore this post.
    Cheers,
    George
    Sep 2010
    Oklahoma City, OK
    3,464
    602
    1510
    You said pipe couplings, are you trying to use a socket on railroad union?
    Apr 2011
    VA
    57
    7
    Quote Originally Posted by gmatov View Post
    Cheers,
    George
    It is for an assembly I build, I would like to avoid the "bite" since it will look sloppy. The coupling sits 2' down inside an acrylic chamber that is easily seen. I would also like to use a torque wrench to tighten, thus the socket form.
    Jun 2008
    Roanoke, VA
    615
    181
    208
    Would a crow's foot with an extension fit?
  11. #11
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    927
    Create swaging tool, force into a properly sized tube/pipe (perhaps with use of heat).
    Weld a socket onto the opposite end, for your 1/2 drive socket.
    How much torque is expected?
  12. #12
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    These folks list both 8 point double-square and 8 point octagonal sockets.
    ++ IMPERIAL-Newton Corp ++
    IMPERIAL-Newton | Industrial Impact Sockets
  13. #13
    Jul 2011
    Lac Du Bonnet,Manitoba
    637
    60
    72
    i needed a wrench for an 8 sided nut used on a hand well pump.
    drew it out on a piece of plate,torched it out with the plasma and dressed it with the grinder and sander.
    easy enough to make a crow or crabfoot wrench this way,if the square drive is too tricky then weld a socket in its place.torue wrench would need a little calculating,but it all depends how close the torque needs to be.
  14. Likes oldbikerdude37 liked this post
  15. #14
    Apr 2011
    VA
    57
    7
    Quote Originally Posted by S_W_Bausch View Post
    I did this except I used square tube and notched it down the corners, pressed to right ID and then welded it up. Square wrench works dandy for a octagon. Thanks for the brainstorm everyone!
  16. #15
    Jun 2009
    Near:Louisville, KY
    1,712
    158
    379
    The socket that you found on fleabay is an axle nut for truck Rear Axles. OTC tools found at heavy truck parts distributors will likely have what yo want.
    SPX OTC
    or
    KD Tools
