zimbo
- Apr 22, 2017
- Richmond, VA
Morning all,
I am stumped on how to remove the bearings on this German assembled part. Part is off a Fella SM210 hay mower cutting disc gear box and the they consider this a through away part, new one is $1800! With covid lock down I cant get a new one from S Africa, so figured to swap broken tooth gear with another unit whose gear and bearings are in good shape.
Before attempting to tear it apart and break something figured would get a second opinion. I assume the bearings are roller ball bearings, (the hex bore drive gear has needle bearings)
I am not sure if they just merrliy pressed the parts together, heat shrink it? [
Power is coming in from one side of this shaft and out the other side vertically to the cutting disc.
Will post more detailed pics
ATTACH=CONFIG]286616[/ATTACH]
