matthewlee
Hot Rolled
- Jan 7, 2012
- st louis
Hi PM
I have a job where Id like to use a step drill.
Material for the parts is 6061 alum
The hole is .125" dia and is .10" deep.
Could someone guide me on how to make a step drill that would drill the .125" hole and also generate a small 45 deg chamfer?
Or I could even purchase a couple if someone is proficient in making high quality ones. Id like to learn, but it would probably benefit us both if someone could whip them up for some payment.
I have a import "Deckel" cutter grinder and a Black Diamond drill sharpener but am a little lost on how to generate the proper relief if I was to spin a drill bit down and also how to make the 45 deg section for the chamfer.
