Help Identify Steel: 7.75%Cr 18.32Fe .04%V .91%Ni
Results 1 to 14 of 14
    Feb 2014
    Sunny South West Florida, USA
    2,757
    10440
    3185
    Default Help Identify Steel: 7.75%Cr 18.32Fe .04%V .91%Ni
    As the title says...
    My metallurgy is not that awesome, I generally read up on things when I need to know them, or ask here. I was just handed a printout from an XRF gun and asked to identify the alloy.
    Again, the numbers are:
    7.75% Cr +/- .07%
    18.32% Fe +/- .15%
    .04% V +/- .01%
    .91% Ni +/- .01%
    Apologies if it's a dumb question. I'm still looking at various steel grade charts, but not finding what I'm looking for, I figured someone here might be able to say "Hey dummy, it's XXXX!"
    Dec 2005
    Waukesha, WI
    1,693
    384
    525
    XRF often doesn’t work. Notice that your numbers add up to about 28%. So your material is 72% unknown.
  3. Likes MattiJ, TeachMePlease liked this post
    Feb 2014
    2,757
    10440
    3185
    Quote Originally Posted by adh2000 View Post
    For whatever reason, those are what the gun is preprogrammed for. Presumably because with those numbers we can tell 303 from 304 from 316 from 17-4 from 17-7 etc.
    Presumably. I know even less about our receiving inspection methods than I do metallurgy.
    May 2017
    FINLAND
    1,685
    479
    780
    Either you have typo in your numbers, XRF gun has gone nuts on this sample or its some weird alloy.
    I'm not sure if aluminium shows up on all XRF guns at all, but for aluminium base metal the alloying would be really weird.
    For example this would sound lot more plausible:
    8 Cr
    18 Ni
    0.9 Mn
    but its all guesswork until you check your print
  6. Likes TeachMePlease liked this post
  7. #5
    Feb 2014
    2,757
    10440
    3185
    I was just handed these numbers and told to figure it out.
    I'll send another sample to the XRF and see what I get back. I know nothing else about this. I don't even know WHY they want to know... I just do what I'm told
  8. #6
    Jul 2004
    Houston, TX USA
    29,623
    Its simple. If you have ONLY 8% Cr and a dab of two others, FE has to be about 90% - assuming some sort of steel
  9. Likes TeachMePlease liked this post
  10. #7
    Dec 2005
    Waukesha, WI
    1,693
    384
    525
    Offhand I can’t think of any alloy that’s 18% iron, something is hosed up. You should be able to tell if it’s aluminum, steel, stainless, ceramic, wood, masonry, etc. Start there and reset the xrf gun accordingly.
  11. #8
    Feb 2014
    2,757
    10440
    3185
    Well, in today's "I'm gonna smack my coworker" moment...
    I went to get a sample of WHATEVER this is, so I could have it XRF'd again...
    It's a freaking bit driver he ordered from McMaster.
    I found the McMaster part number and have contacted their customer service to get an answer.
    I'll update y'all when I find out what it is.
    Thanks for the input, sorry for wasting your time.
  12. Likes sfriedberg liked this post
  13. #9
    Dec 2005
    Waukesha, WI
    1,693
    384
    525
    I wish my business was so fat I could afford to have guys running around xrfing driver bits.
  14. #10
    Feb 2006
    Indiana
    12,824
    664
    3809
    Quote Originally Posted by johnoder View Post
    Or, to put it another way, if the iron content is 18.32%, then it is not steel. Sounds like a waste of time all around.
    Larry
  15. Likes TeachMePlease liked this post
  16. #11
    Feb 2014
    2,757
    10440
    3185
    Quote Originally Posted by L Vanice View Post
    Larry
    Well, I talked with him after this post, turns out, he hadn't sent me on a total wild goose chase. There was a sample part in the same box as the drivers, but he had it with him, so when I looked in the box, all I saw was the drivers (McMaster got right back to me though, and let me know the drivers are made of 8740!)...
    Turns out the sample is a fairly complex, small diameter part, with an irregular surface, and he said the guy with the XRF gun had problems getting a good reading, and took multiple shots before they even got the reading I was given. So I explained that with the numbers he had given me, there was no way to make an identification, since the less than 16%Cr immediately told me it wasn't stainless.
    He accepted that it's unobtainium and we've moved on.
  17. #12
    Dec 2005
    Waukesha, WI
    1,693
    384
    525
    Sounds like a great place to work.
    Joe: "The results totally screwed"
    Bob: "Oh well, want to get some lunch?"
  18. Likes TeachMePlease liked this post
  19. #13
    Feb 2014
    2,757
    10440
    3185
    This is why we
    It's not vital to our work... Just something that would have helped to know.
    The day goes on.
    We get hot dogs for lunch today, so there's that.
  20. #14
    Jul 2006
    Arizona
    4,585
    18388
    4303
    Quote Originally Posted by TeachMePlease View Post
    Is the part magnetic or not? I don't have access to an XRF gun but a simple magnet sometimes speaks wonders about mystery metal.
