Strostkovy
Titanium
- Oct 29, 2017
I'm trying to swap out a 30 HP 3 phase motor from a Timesaver belt sander and replace it with a 10 HP single phase motor, due to a lack of three phase power and insufficient single phase power to convert to three phase power (though I tried my best). For the application we are using it for the single phase motor will have plenty of power.
The issue is that the original motor has kind of an odd pulley, and I broke it trying to remove it. It's still stuck on the shaft of the original motor. I can't remove the pulley on the machine end either.
The pulley has a bore of 1-7/8" (though it would be nice if a replacement had a 1-3/8" bore to fit the new motor without a bushing) an OD of 6-7/8 and 5 grooves for 5 3/8" wide V belts. Each belt handles 6 HP apparently. The belts are pitched at 0.41".
I have contacted Timesaver before and they are very proud of their replacement parts.
