ManualEd
Stainless
- Oct 13, 2014
- Kelowna, Canada
Anyone have an idea what these clamping mechanisms on the binocular tripod mounts are called?
MUTNT Binocular to Tripod Adapter Kit. "Free Shipping" | Hunters Technology
It appears they are a complete unit that is held into the end with the small set screw.
It has a plate with a hole in it that offset from the bore. You press in the spring the slide the plate in line with the hole so that a pin can be inserted.
The plate will pop into a groove in the pin, and then you turn the nut to put more tension on the plate locking the pin tightly.
Thanks for any help!
