bugman53
- Oct 7, 2007
- Greensboro NC
Looking for ideas to replace the chuck on a Kwik Way SV valve Grinder
The chuck has .002-.006 run out. It is the 6 ball style. I replaced the balls with new .531 balls and no change. It is not repeatable. If I chuck up a drill rod and rotate it or re chuck it the high spot is different every time. The chuck shaft itself indicates in within .0002-3. It does have wear on the ramps that compress the balls. It looks to be evenly worn on all the ramps I was hoping to get lucky with new balls but that did not happen.
I am looking to get the run out less than .001". Hopefully less than .0005.
I am not going to use this machine more than once or twice a year so if I have to indicate each valve in each time that is not really a problem. but it is not worth it to spend several hundred dollars on a new chuck no more that I use the machine.
Does anyone have any ideas for a cheap way to replace the chuck? I was thinking machining the existing to fit an ER32 Colet Chuck. But with out a way to adjust it no guarantee it will be much better.
It seems something that is adjustable would be a good idea to dial it in. Any ideas? I like the idea of an er32 collet mounted with some kind of adjustable mount.
