steelsponge
- Aug 24, 2016
Went to remove a stuck chuck on my southbend 9 model a lathe. Before I got to serious in removing the chuck and backplate I decided to remove the chuck from the backplate take it completely apart clean it put it back on the backplate and remove the entire assembly at once.
Got the chuck off of the backplate took it completely apart cleaned it thoroughly in kerosene. Wiped it off and tried a preliminary assembly to make sure everything turned freely and the jaws were timed correctly as I turned the scroll. Number 1 first, number 2 second and number 3. This chuck has 3 pawls I'll call them to adjust the jaws. I tried sliding the jaws in their numbered slots to make sure that they slid freely. For some reason no luck. They are to tight. Three is the worst. Put, it all together properly, oiled everything, went to adjust the jaws to see if they come together like they should and after about 2 turns it became increasing more difficult to turn.
Before I took it off of the backing plate I could adjust it somewhat, but it was stiff. So I thought a thorough cleaning would be the ticket. Now I have a chuck that is very clean but doesn't turn freely. I checked and double checked all of my numbers to make sure they were all correct. The main, planetary scroll gear turns freely even without oil, all the pawls go in nicely, their keepers line up nicely. Can't figure out what am I doing wrong. Does anybody have any thoughts. Rohm chucks as I understand it are made very well. With all of the gearing removed and the body of the chuck and the 3 jaws in their proper slides they are stiff, too stiff. Is their a way to correct this? Thank you for reading, Clyde
