Desert Fabworks
- Aug 3, 2012
- Arizona
Just brought this beauty home a couple days ago. Was a great Craigslist Find. The saw is in good shape. Just to have a good starting point I replaced the two belts and I changed the oil in the transmission. I found the manual online, but I find that it does not have as much info as I had expected. The paper tag on the inside of the machine shows it was quality inspected in 1966. They do not build them like this anymore.
The saw is missing the Taper pin, table insert, miter gauge, fence and a blade.
I found the taper pin online but did not want to pay the ridiculous price of $33 for the insert. Or the $$$$ for the original fence.
Can anyone suggest a fence setup that would work on this machine. I have heard Kreg and a couple others but do not know how compatible they are.
Also has anyone found a replacement table insert that will work for this saw.
Last question is on the blade. The machine says 94-96 inches blade. I plan on only cutting metal with this saw. The majority of my cutting will be 1/8 and 1/4 steel plate. Steel tube with walls of .065 to .120 and some occasional aluminum. I dont know a lot about blade selection and was overwhelmed by the choices. I was thinking a Bi-metal and looking at Lenox or Starrett. If someone could suggest the teeth setup for this type of cutting and If I should be on the high side of the blade length for this machine or the low side. On the width I was thinking I would get a couple sizes for straight and contoured cuts but not sure what widths are best or what this machine can handle.
