Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
I have a SPI (Nikken) quick change tap holder that's non reversible for spindles that reverse. Each holder accepts only the tap it's made for and factory adjusted for the torque required so that clutch will release and not break the tap. They can be adjusted if other torque is required. At one time I had the entire set from @4 to 1/2" (none smaller than #4 and larger than 1/2" were made) for the #1 size head. I'm missing a couple of the fractional sizes. Blitz, tapmatic, Kennametal and I'm sure others make a similar holder. I would like to complete the set, does anyone know if the other brand will fit? MSC no longer has them, not sure if they were discontinued.
