rcn11thacr
- Dec 5, 2019
I recently purchased and use a Winona Va Norman Boring Bar in my shop to bore small engine cylinders. The model is: CB1401. Soon I will be in need of more inserts for this machine. The company wants over $220 for a box of inserts and I am interested to see if anyone has found other sources of inserts for this machine at a reasonable price? The factory part number for the inserts is: 35-4318 WINONA REPLACEMENT CRBD INSERT. The inserts I have currently are:
Triangular
Relief Angle I believe is 5 or 7 degrees
Accuracy: ?
IC: The actual hole diameter is 5/32
Thickness: 3/32
Cylindrical hole with no countersink
No chip breaker
Single sided cutter
NOTE: The corners of the triangle have a very pronounced wiper edge.
Anyone using a Van Norman CB1401 or is much better than I am at insert geometry and ordering, I would appreciate your input. Thank you.
Triangular
Accuracy: ?
Thickness: 3/32
No chip breaker
Single sided cutter
