Zip
- May 25, 2007
- Champlain, NY
I need a hydraulic cylinder seal kit for my 6000 lb scissor lift. It has 2 cylinders and one is leaking via the weep hole at full extension. The only part number I see is on the ram collar: 12040609, the cylinder body is 3.25", the ram diameter is 1.75 and the closed pin to pin distance is approx 22.5". Can you help?
