Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
As I have mentioned in other posts I don't do production. Retired and sold my large shop but still have a small shop at least by my standards. Simply put I have one of nothing except one too many!
I do quite a bit of work for local Poultry plant so all I cut is Stainless Steel, some steel in the non food areas. Usually I'm trying to make parts last longer and in this case I'm using 17-4. I purchased precision 17-4 from McMaster Carr 25mm. I turned the end 20mm X 45mm long. Drilled 10.2mm x30mm deep to the point of the drill like the original. Counter sunk the opening. Bottoming 4 flute M12 X 1.75 hand tap will go 10 turns into the original. Started with taper hand tap in the chuck then with a center to hold the tap straight used a wrench to turn the tap, when torque required was enough to turn the spindle in neutral set to the lowest speed I stopped and changed to a Regal Beloit spiral point 3 flute TIN coated plug tap. Didn't do much with Tap Magic Pro fluid. I redrilled the hole 27/64". By using the spiral point tap until it turned the spindle, then the bottoming tap, back to the plug until the bottoming tap screwed in 12 turns. I have 19 more to do! Is there a tap that will do a better job? I'd like to run a tap full depth, possibly finish with a bottom tap.
